700 SCI Stainless Marine manifolds >
Old 11-30-2021 | 07:43 PM
Question 700 SCI Stainless Marine manifolds
In the search for a new Fastech I have come across a beautiful 382 with 700 sci. The motors were just rebuilt (due to leaky headers, in freshwater too) and I want to minimize my chances of ruining the freshly rebuilt motors. The owner did not replace the headers after the leak, he just re-welded them. The boat is going to be used primarily in salt water so Instead of swapping on some CMI's for 20k, I was hoping to get some peace of mind with stainless marine's manifolds. What is the general consensus on 700's with these risers and manifolds? Do I need to reflash the ecu's due to more back pressure? While I am on the topic, how reliable are the 700's in salt? What should I be careful of ?
Formula292fastec is offline
Old 11-30-2021 | 11:29 PM
IMO, the Stainless Marine's will be your best replacement option for salt water use. Biggest issue is that the Merc heads will need to be drilled and tapped to accommodate the SM's.
No reason the PCM would need reflashed. The SM's should flow just as well as the CMI's.
Griff is offline
Old 12-01-2021 | 05:34 AM
Not Sure what Generation Stainless Marines you plan on putting on but I would almost guarantee the Gen 3's would out flow the stock CMI'S
bigfarmer is offline
Old 12-01-2021 | 07:16 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Go with Stainless Marine, you won't lose any performance over your CMI's. Stainless is going to have a 20% increase in price soon, so don't wait too long!
https://www.diamondperformanceparts....ducts/sku17426
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 12-01-2021 | 09:20 AM
How about the hardin 525/600/700 exhaust that doesnt require any drilling of the heads??
https://www.hardin-marine.com/p-8161...-12-pipes.aspx
302Sport is offline
Old 12-01-2021 | 10:13 AM
Yes I was worried about the stainless marine manifolds fitting. I haven’t heard much feedback on Hardins product for the 700’s. What are your thoughts on Hardin vs Stainless Marine
Old 12-01-2021 | 01:33 PM
When Stainless Marines Rott out they leak into the bilge, when regular Headers Rott out they can leak back into the Enginess.... as far as performance i couldn't tell you.
Old 12-01-2021 | 01:43 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
No loss of performance with Stainless Marine. Pat installed them on several of the Active Thunders that he factory maintained for customers; after the OEM CMI headers started to fail with use cracks.
Sydwayz is offline
Old 12-01-2021 | 06:06 PM
jbraun2828's Avatar
I had stainless marine on a set of 700 sci’s in a 39 top gun. The boat ran just as fast as any other stock boat with cmi’s so definitely no power loss. Two new holes need to be drilled and tapped but I think it’s worth it. As mentioned if they were ever to leak, they leak externally not into the engine. Another benefit is the riser/tailpipe is all one piece and is so much easier to remove than a header, one clamp versus 8 header bolts.
jbraun2828 is offline
Old 12-02-2021 | 06:49 AM
I had them on my Top Gun I believe I had 38" centers and they were kinda tight, I'd try to find a set to test fit before I bought a pair. I also Powder Coated mine silver to match the rest of my engines a bit better....
