-   -   Keith Eickert Headers (https://www.offshoreonly.com/forums/general-q/37417-keith-eickert-headers.html)
Kirk 11-21-2002 04:53 PM
Any comments out there based on experience with Keith Eickert cast aluminum headers with the 32 inch runners.
Performance, sound, reliability, etc?
KAAMA 11-21-2002 05:53 PM
Kirk,
Look for the thread "Aftermarket Exhaust" started by "Formulafastech" it's probably on the next page or two over. There was a very heavy and thorough discussion concerning all the different types of aftermarket exhaust systems within that thread that should keep you interested and answer a lot of questions for a good while! :)
454hoho 11-21-2002 10:27 PM
Mark/ kirk
I have a very old article from Hot boat mag. that they tested different exhaust headers and found eickert out flowed all others by about 4-6 hp.(again old article) The only problem is CMIs look great,nice and shine. I have the eickerts!
Go to eickert web site, I think they had the flow/hp graph:cool:
Dean Ferry 11-22-2002 06:45 AM
I too have a pair of Eickerts, they are the well designed and the BEST TRUE 32" HEADERS available! Mine have about 250 Hrs., ALL salt water and are still running strong!
The only draw backs are they aren't the eye candy like CMI's, (Although I've seen some KE that were powercoated Merc. racing Blue, and they were BEAUTIFUL), the cost $$, and they are LOUD!! I put Shotgun III mufflers on mine and that really helped!
Good luck, I don't think you can go wrong with them.
MD
454hoho 11-22-2002 10:28 AM
Dean ???
Do you have the old style eickerts that have the alum. water distribution bar. or the newer style that has the T fittings. I had the old bar style and just switched over to the "T"s (what a job).
Did see some lifting of the powder coat around every water intake port. but removed 28 pounds of weight:D :D
formula31 11-22-2002 11:33 AM
Probably the only downside of these is, from personnal experience in a friends Scarab (900hp), is the meltdown that will happen quickly at WOT if you lose water pressure. We melted the headers before the engine water temp or pressure gauges let us know. I am putting low pressure switches on my gils this winter and would suggest them on the PF/Eickets too.
vanmeterf 11-22-2002 11:51 AM
I ran a set for 3 seasons and the next owner is on his 3rd season without problems the best thing I did was install studs instead of using supplied bolts it made install and removal a breeze.
454hoho 11-22-2002 12:52 PM
thanks Van & 31
I have Gaffrig gauges with built in alarms, might be a good idea if i wire in large red shift type shift lamps into water alarms. thanks once more
bob 11-22-2002 10:52 PM
Formula 31/Your friend probably(fortunately) had a closed cooling system which took some time to heat up after the cooling water coming thru the pipes was shutdown. If he hadn't had closed cooling he would have seen the engine temps go up a lot qucker I'll bet. KE's pipes, as well as staniless steel pipes do not run well without water. Stainless can be prone to cracking after being overheated. An alarm is definetly a good idea.
