34 in center what exhaust?? >
Old 12-10-2021 | 07:58 AM
nocigarette's Avatar
Default 34 in center what exhaust??
I was wondering what the tightest center you could run stainless marine gen 111 exhaust. i have one set of manifolds already and all the material to build my tailpipes but i think it may be to tight to use them.
any help would be appreciated.
nocigarette is offline
Old 12-10-2021 | 08:57 AM
Think Gil’s need 34 min for a reference. Cmi etops 33. Not certain on sm gen 3’s
getrdunn is offline
Old 12-10-2021 | 09:03 AM
that is what i was afraid of. i believe the gen 111s are a bit wider than gills. i think i am at 34 1/4
Old 12-10-2021 | 10:56 AM
My old boat was extremely narrow c to c. Etops would touch at 32 3/4. 12 meter is only 33 1/2 and the big tube stellings clear with about 1 1/4 btwn center pipes. That will tighten up some with the aftermarket heads with raised exhaust.
getrdunn is offline
Old 12-10-2021 | 11:50 AM
Depends what deck height and heads. On a 9.8 deck with standard exhaust ports I believe the fit at 34, raised port heads 34.5, tall deck 35
Unlimited jd is offline
Old 12-10-2021 | 12:24 PM
You can angle mill the exhaust flange on the Gen 3 manifolds so they hug the block better. My tall decks are tighter than 34 inches and the milled Gen 3 manifolds fit.
kvogt is offline
Old 12-11-2021 | 08:29 AM
TomFTM's Avatar
bingo. That’s what jerry did for me when I put gen 3 ‘s on my OL. Mine were at 34 tall deck , Merlin heads .
TomFTM is offline
Old 12-11-2021 | 03:04 PM
thanks a bunch guys. i double checked today and i am right at 34 1/4 i have one pair of gen 3 already, maybe i will mill them just to be safe. i have to build my own tailpipes anyway.
U happen to remember how much was milled or at what angle?
