Heads / int cc’s? Vs flow Vs cross section Vs air speed >
Heads / int cc?s? Vs flow Vs cross section Vs air speed
Old 01-17-2022 | 01:13 PM
  #41
I have the large t-stat controlled oil coolers and will be running in the Great Lakes. Glad you brought up the spring oilers they seem to be more commonly used. I should’ve considered the piston oilers but a little late. Short blocks assembled!
getrdunn is offline
Old 01-17-2022 | 01:16 PM
  #42
Im seeing around 205-210 oil temps and 140 water,also running a X over no t-stat, I need to do some restricting on the inter-cooler dumps to raise my block water pressure, and -6 dumps on both sides of the rear of the intake
Did you ever see what Rookie was experimenting with and using. Pretty cheap and effective to achieve desired pressures etc. Little more sanitary than small gate valves I was going to rig.
getrdunn is offline
Old 01-17-2022 | 01:21 PM
  #43
we run the 2 stage water pumps -20 to the bell housing then 2 -16 to the x over then 2 -16 from intake to headers we restrict it at the exhaust pipe so header has full flow to try to stop hot spots.
KWright is offline
Old 01-17-2022 | 01:22 PM
  #44
the spring oilers are definitely worth running IMO.
KWright is offline
Old 01-17-2022 | 01:42 PM
  #45
Originally Posted by KWright
We absolutely love the boat. I would like to whipple it so we could run with the outboard cats. My concern is being able to sustain 8 to 10 minute pulls. If you watch my videos all the boats we ran with are supercharged. They just can't sustain the long consistent pulls. Not sure why. Maybe heat, inconsistent fuel supply
Interesting, have you spoke with any of them or just what you speculated?
If you have spoke with them, oil, water, or intake air temps getting too high? All or one?
What do you reckon the water temps were those days? As in the water your were boating in.
Seems a properly tuned, fueled, and charge air cooled setup shouldn't be "held back".
cheech is offline
Old 01-17-2022 | 01:45 PM
  #46
Which ones are you running? I need to order asap.
getrdunn is offline
Old 01-17-2022 | 01:55 PM
  #47
not sure of lake temp probably low 80s. Yes did ask a few, mostly the replies were didn't want to push it that hard. So nothing concrete. One did say temps were getting high.
I agree if you get your setup right you should be able to maintain. Maybe with the merc. boats temps were close to putting them into safe mode? Not sure couldn't get a clear answer.
KWright is offline
Old 01-17-2022 | 01:59 PM
  #48
Jeff Johnson he builds them into his valve covers.
KWright is offline
Old 01-17-2022 | 02:04 PM
  #49
One was 1075's the rest were 700's and I think 2 600's. So mostly merc. Some had the stage 3 or 4 whipple upgrades.
I do know a 700 with the stage 4 has heat problems. It was a very hot humid day that day also.
I remember reading that the 700sci heat exchanger maxes in the 950 range. If that was Dyno conditions, it’s probably lower in a boat on a hot day.
hogie roll is offline
Old 01-17-2022 | 02:36 PM
  #50
F-2 Speedy's Avatar
Im running 2 stage pumps also -20 from the transom feeding the pump, -16 to to the x over, -12 to the inter-cooler and out, -12 off the T-stat housing to the headers, Im dry to the tip so I cant restrict there so I figured the cooler dump would be the easiest.
F-2 Speedy is offline
