Heads / int cc’s? Vs flow Vs cross section Vs air speed >
Heads / int cc?s? Vs flow Vs cross section Vs air speed
Old 01-17-2022 | 12:24 PM
  #31
how many are roots vs ?.....I like the EFI Whipples.....
He’ll have to answer that however ck out his thread. I believe it’s in the fountain section. Very cool!!!
getrdunn is offline
Old 01-17-2022 | 12:26 PM
  #32
One was 1075's the rest were 700's and I think 2 600's. So mostly merc. Some had the stage 3 or 4 whipple upgrades.
I do know a 700 with the stage 4 has heat problems. It was a very hot humid day that day also.
KWright is offline
Old 01-17-2022 | 12:31 PM
  #33
F-2 Speedy's Avatar
Not sure what a long pull is but one off the legs in the Cig event @ LOTO is 27mls we run around 80 ( water permitting ) last yr is was hot engines were cool, I guess it all depends on the set up
F-2 Speedy is offline
Old 01-17-2022 | 12:37 PM
  #34
It was in the 90's that day. We had legs that length also.
we consistantly were running 100 to 105 that day, right around 5900 rpm.
KWright is offline
Old 01-17-2022 | 12:42 PM
  #35
So the million dollar question is, if I whipple these can I still do 10 minute pulls at 115 mph, or am I going to run into problems.
KWright is offline
Old 01-17-2022 | 12:47 PM
  #36
I love it. Awesome job and I know it’s easy for me to say however I vote leave it alone and just be happy with the fuel capability to deliver. You’ve got it so dialed in and trouble free it seems. Enjoy all the dedication and hard work you put into it 😉!!!
btw by the length of the vids and speed maintained throughout - I’d assume your dropping the hammers for several miles. 30 plus No?
getrdunn is offline
Old 01-17-2022 | 12:50 PM
  #37
F-2 Speedy's Avatar
what oil and water temps are you currently seeing on a hard run......you wont run those kind of speeds weekend main channel on loto.............
Old 01-17-2022 | 12:53 PM
  #38
The engines really like the 5900 6000 rpm zone, they will pull up to 6300. It will definitely remain the same this summer.
KWright is offline
Old 01-17-2022 | 12:59 PM
  #39
we run a cross over system with no thermostat so we never see over 105 on water. Oil is thermostat controlled we use both plate coolers in the bell housing for oil. It will go to 245 then settle in at 220. We also run spring oilers and piston oilers.
KWright is offline
Old 01-17-2022 | 01:12 PM
  #40
F-2 Speedy's Avatar
Im seeing around 205-210 oil temps and 140 water,also running a X over no t-stat, I need to do some restricting on the inter-cooler dumps to raise my block water pressure, and -6 dumps on both sides of the rear of the intake
