What would be the best cam?
You don't want a "choppy" cam in a low compression turbo 454 with cast components. The cam dictates the Rev range where the motor is most efficient at making torque. Your cast motor should be kept below 4900-5000 rpm.
We also have no idea how well the turbos will spool up with a cam that has a torque peak way faster than your "planing rpm".
If somebody ran it like it is, then start there.
You really shouldn't jump so far ahead of yourself.
Besides, you need to creep up on speed with your new hull..
Find the casting numbers on your pistons and send photos.. Find the casting numbers on your heads. Find the stamped number's on the face of your cam. Those are good starting info we need in order to help you..
I agree,...also, I don't know if it has been mentioned yet, but a Merc 454cid 330hp engine come stock with oval port heads---the earlier heads usually had the "049" castings and the later Merc 330's had the "peanut port" designed heads, therefore, if you try sticking a bigger cam in the Merc 330, then it will most likely fall on its face and become a dud---plus other issues like valve guide height clearances with the spring retainers, etc, You might..be able to at least get away with a very slight upgrade with perhaps a roller cam, but not much---you need to really do your homework. If you are looking for more power, then I would suggest doing some bowl-port/short-side radius work on the heads, and upgrade to a hydraulic roller if it can be done on a Merc 330, but any cam upgrade will be super limited. Check with a reliable marine engine builder that is familiar with Merc BBC stuff....especially the old 330.
