-   -   Offset lifter bores in roller blocks? (https://www.offshoreonly.com/forums/general-q/375328-offset-lifter-bores-roller-blocks.html)
stinkbomb 04-07-2022 04:12 PM
Are the lifter bores in a Gen 6 block offset like flat tappet blocks? Yes I'm wanting to put a flat tappet cam in there.
the deep 04-07-2022 04:20 PM
My Gen 6.
https://cimg5.ibsrv.net/gimg/www.off...a83cd01c6c.jpg
stinkbomb 04-07-2022 04:30 PM
Originally Posted by the deep (Post 4828104)
My Gen 6.
Looks offset to me but is it?
Unlimited jd 04-07-2022 05:23 PM
Lifter bores are in the same place. I have a gen 6 block here someone put a flat tappet in.
SB 04-07-2022 08:34 PM
X 100.
No such thing as offset bores. You can put flat tappet cam and lifters in there if you want. But do you really want, really really want ?
stinkbomb 04-08-2022 05:30 AM
Interesting, so a roller cam has the lobes moved on center of the lifter bores? I'll have to measure that if I get my hands on a flat tappet cam one day.
Unlimited jd 04-08-2022 06:46 AM
Originally Posted by SB (Post 4828147)
X 100.
technically the flat tappet cam lobes aren’t centered in the lifter bore so the lifters rotate.
The roller cam lifters aren’t centered over the lobe either.
And why would you want to use a flat tappet?
sutphen 30 04-08-2022 07:27 AM
can only get a 3/4 race cam in flat tappet.:D
SB 04-08-2022 07:46 AM
https://cimg5.ibsrv.net/gimg/www.off...4a7f160d67.gif
stinkbomb 04-08-2022 07:48 AM
A good flat tappet in my application will have more longevity. Guys think 200 or even 500 hour top-end rebuilds are acceptable but I don't, not for what I'm doing.
