EMI Drive Showers >
EMI Drive Showers
EMI Drive Showers
Old 11-24-2002 | 02:26 PM
rpm
If you are referring to the Innovative Marine drive shower, yes they also produce an alpha version - same money.
Rod
Old 11-24-2002 | 08:01 PM
baja bailey's Avatar
Originally posted by Griff
The EMI drive shower is nearly, if not, identical to my IMCO drive shower. You may want to price the Imco's also.
I trashed the pick up on mine when I hit a small piece of debris in the water. I tapped the water jacket on the upper drive case and now feed it from there. It puts a chitload of water onto the top of the drive.
Your right, the EMI seems to be exactly the same as the IMCO..I have had both, could not see any difference between the two in any way...
baja bailey is offline
Old 11-24-2002 | 08:42 PM
RPM,
Will those fit the alpha I gen 2? Does the flex hose install to the outdrive by just drilling a hole? If so how do I order one.
FlyFast is offline
Old 11-24-2002 | 10:06 PM
rpm
Yes, they will fit Gen II also. Send me an email with contact info including daytime phone number. You need to drill (2) holes in the cavitation plate. One for the pickup and the other for the fastener to hold it down. Comes will all required hardware and instructions.
Rod
Old 11-25-2002 | 10:04 PM
Innovative Marine drive shower. Dont even question it! Ritchie builds the best unit and it looks factory. Greg
HPJunkie is offline
Old 11-26-2002 | 10:48 PM
Ratchet's Avatar
Default Simrek Showers
Originally posted by HyperBaja
Ive been told the simerek will mist off at high speed and not shower down on the drive.
Looks like a good deal for 145, no other ones that style are that cheap.
I installed a set of simrecks on my old boat, which had alphas. we went into a channel, and it was like glass. Having no swim platform, you could lay on the sun pad and peek over the back. We took it out to about 70 and trimmed it all the way up (ok, maybe this wasn't the smartest thing to do, but we did it anyways). But you could clearly see the water spraying all over the sides and the tops of the drives.
I'm not sure what you mean by misting ?
Personally, I think this is a fairly simple design that works well I've seen many people around her use them (the simrecks) and even when cruising, you can see them spraying the drives pretty good.
Just thought I'd let you know my experience with them Of course, the "high speed" you mentioned may be faster than we were going ?
Ratchet is offline
Old 11-27-2002 | 03:10 PM
Quiet Storm's Avatar
I was told that none of the drive showers work on cats because they ride so far out of the water. It seems to me that you could attach the pickup to the transom with a braded line to the shower. Does this sound right?
I have Simrecks on my Checkmate and they work great. No white chaulking at all. It was a trick to get them on with the Marine Machine steering but worth it.
Quiet Storm is offline
papawayne@comcas
Drives and Lower Units
26
07-13-2010 08:18 PM
raytart
Nordic
2
05-24-2008 08:46 PM
mobilecal
8
05-27-2004 10:17 AM
Southbound35
Powerquest
6
12-17-2003 05:59 PM
shawn
02-25-2002 10:27 AM
