700 sci top end help
Hey guys,
‘My 700sci’s are at 260 hours and i am preparing to change the springs, retainers, rockers etc.. my question is it required I do a valve job plus head work (machining, resurfacing etc) or can I just change the components without going to the machine shop. Thanks |
What do compression and leak-down tests look like? That will tell you a lot.
Reach out to Snapmorgan here on OSO, I believe he was running 700 sci's. Very knowledgeable about them.
if the valves don't leak,,no signs of reversion,,then just do springs,seals and if you like rockers
| All times are GMT -5. The time now is 12:09 AM. |
