Bbc 509cid fuel line?
Hi, need opinnions for correct size fuel line for 500hp bbc, quadrajet carb, holley 110gph pump, AN-6 from pump to carb. My tank has dual pick up tubes, 0.33" inside diameter each. Should i use both pick ups and AN-8 from tank to pump, or is one pick up enough?
More on sizes from Fuel Labs:
https://www.fuelab.com/blog/understa...ered-thread/30
Can't help you with your balls!
I am running supercharged big blocks electric fuel pumps and Sniper EFI on -6 lines throughout without issue. I am around 620HP
Originally they were 525SC clones with mechanical pumps and 3/8" line throughout.
What’s cool about electric fuel pumps, is that you can measure your fuel supply ‘as installed’ pretty easily. Return line into a fuel jug.
Measure by weight or volume vs time. Whichever you can do more exact.
So one 3/8" seems to plenty for my workhorse 👍 local store have these filter/separators in stock, 60gph, what you guys think?
https://www.google.com/search?q=east...P5IiS32zsDXRXM
