-   -   Battery switch problem (https://www.offshoreonly.com/forums/general-q/375817-battery-switch-problem.html)
Padraig 05-23-2022 01:08 PM
I have two batteries and a Blue Seas manual switch. When the starboard side is on I get good voltage to the dash and engine. When the port side is on I get almost nothing at the dash and will not turn over the engine. A vom at the battery reads 12.4 volts. All connections at the switch are tight and corrosion free. Where do I go from here, please?
Padraig
F-2 Speedy 05-23-2022 01:14 PM
Not saying this is the issue but do you have the blocks grounded together ?
Padraig 05-23-2022 01:18 PM
Single engine boat, Velocity VR 1
Padraig
SB 05-23-2022 01:19 PM
Padraig
so, back of switch at connection posts…..bad side still shows 12.4 volts ? But cable out post (one to starter usually) shows what when bad side switched on ? If low like your gauge this shows bad switch.
https://cimg1.ibsrv.net/gimg/www.off...78dd14fdb.jpeg
snapmorgan 05-23-2022 01:26 PM
12.4V is only about 75% charged. Leave volt meter attached to battery while cranking and see what it reads. It shouldn't drop below about 10V
F-2 Speedy 05-23-2022 01:33 PM
Padraig
ooops
Padraig 05-23-2022 01:52 PM
SB I get good voltage at both inputs...when switched on nothing at output terminal. Therefore bad switch??? I assume better to replace them disamble and try to fix? Any thoughts on better switch?
F-2 Speedy Not your fault...I should have described boat. Thanks!
snapmorgan Does notcrank...Thanks
Padraig
SB 05-23-2022 02:04 PM
Padraig
Out put term must show something when switch is on the side that makes your guagescwork and starter engage. Right ?
SB 05-23-2022 02:12 PM
I use Amazon for reviews. Lots of good info buried in there. The Blue Seas switches have fallen apart internally on several peeps. None that i can find find with the perko’s.
Blue Seas:
perko:
Sydwayz 05-23-2022 02:18 PM
Battery switches can go bad, but my money is on one of your batteries has an internal failure. Perhaps a dead cell, open circuit, or loose terminal somewhere.
Wally 05-23-2022 02:22 PM
Those switches are very simple inside.....it maybe just some corrosion on the connection terminal inside. I actually had one switch that had a bad spring on one of the detent balls that holds the switch in position and it wouldn't let it make contact on one position.
If it is indeed a bad switch then take it apart...you have nothing to loose!
One other thing you can try...take the positive batt connection off the switch on the battery that you are having problems with...then switch the move to the BOTH position....and see if there's an output on that terminal with the Voltage meter....If there is then would bet you have some corrosion on the part connected tot he handle and "should" be fairly easy to clean off with some emery cloth or light sand paper. Worse case its a burned and pitted spot and cant be repaired. :(
liberator221 05-23-2022 03:19 PM
Rotate the battery switch rapidly back and forth through all positions and see if that improves voltage readings. If so you have corrosion inside switch as mentioned.
shunter2005 05-23-2022 03:38 PM
I'm with Sydwayz. Had same issue last year. Battery charged up and held voltage, but wouldn't turn the motor over. Took it out and had it checked. Found it was internally dead, cranking amps only showed 100 +. New battery and problem solved.
Padraig 05-23-2022 04:10 PM
I understand and have observed the same but if it shows 12.5volts at the battery and switch imput...shouldn't it show something on the output when switched on?
Padraig
Griff 05-23-2022 04:19 PM
Padraig
If that is the case, then I think it has to be the battery switch. Get a Perko switch.
You could try swapping the input cables to verify
SB 05-23-2022 08:26 PM
Padraig
Yes.
Padraig 05-27-2022 04:48 PM
Thanks to all, specially SB...he called it. Replaced the switch today and it fixed the problem. Can start engine on either battery now. Dam....73 is too old to be squished into that engine compartment doing wireing and switch removal. These old knees were not happy. LOL. Thank God it is a single engine boat. I couldn't find a Perko locally so went with another Blue Seas.
Padraig
