Oil temp issue >
Oil temp issue
Oil temp issue
Old 05-31-2022 | 09:23 PM
Default Oil temp issue
My 500hp carb motor in my new fountain. Is running just over 260deg on gauge. Temp sender is in block just above filter pad. I back flushed cooler (haven’t visually looked silent choice exhaust in way). Changed oil thermostat for shots and giggles. Drops when idling usually. Any ideas. Gonna change gauge because I’m updating dash anyway. But
MikeSXT25 is offline
Old 05-31-2022 | 09:51 PM
Check with infrared gun to verify temp. What is water temperature? Do you run a t-stat?
1MOSES1 is offline
Old 05-31-2022 | 11:22 PM
TomZ's Avatar
When is it running over 260? Cruise? WOT? How long to get to 260+?
TomZ is offline
Old 06-02-2022 | 09:32 PM
Is this freshened engine? What oil pump?what oil pressure you running at cruise and wide open? Suspect your relief valve in the pump.
larose481 is offline
Old 06-03-2022 | 05:34 PM
Rookie's Avatar
What's your timing set at?
Rookie is offline
Old 06-15-2022 | 01:40 AM
Sorry been dealing with fam stuff.
Engine completely stock
-water temp 140-150. Thermostated
-timing 34 deg full advance with wire grounded
​​​​​​—pretty much always in 260-270 oil my temp range on gauge slowly climbs as it warms up and then always above 260 on gauge
oil filter adapter on back of engine very hot
-oil psi 50-70 depending on rpm . 80-85 cold
seems sensor is in block just above filter pad on block
waiting for new gauge and sensor.
Old 06-15-2022 | 03:57 AM
Veteran: Army
It would be worth checking that the oil cooler is plumbed correctly, the water should go in the same end that the oil comes OUT, and the water should come out the same side the oil goes IN. That countercurrent flow is necessary for proper heat transfer. And, even if you backflushed, you might need to pull the cooler to visually inspect that all the tubes are open and able to conduct flow.
DrFeelgood is online now
Old 06-15-2022 | 07:34 AM
Interesting, I need to check mine, could be why I run a bit hot as well.
ThisIsLivin is offline
Old 06-15-2022 | 08:29 PM
Rookie's Avatar
Not at all disagreeing with the Dr that water and oil should flow against one another. I've run it both ways with negligible noticeable differences. Definitely worth looking at. Next, what size cooler do you have? Is this a new issue?
Rookie is offline
