Plug and play for 700 SCI to replace older Vessel view 7?
Hello I hope everyone doing well, I was wondering what Simrad or other makes is plug and play for Mercury 700? To display more data ect ect.
Thank you Skydog
Thank you Skydog
If you already have an NMEA2000 network installed, then any NMEA2000 compatible unit will be able to display the Mercury smartcraft data.
If you only have the Smartcraft wiring in place, then you will either need to use a Mercury device to see data, or install a Vessel View Link which then translates Smartcraft into NMEA2000 for use with other brands of equipment.
