Crank no start >
Crank no start
Crank no start
Old 06-12-2022 | 03:06 PM
Default Crank no start
Im looking for help.
Just installed two fresh rebuilt 496 with whipple supercharger.
Rinda software scanner says all systems go. Fuel pressure, TPS voltage set, spark at the plug. Timing correct per scanner, no codes.
Both motors were a crank no start.
The starboard motor started ran for 15-20 seconds then stalled, now cranks with no attemped to start.
Even tried starting fluid, doesnt even try to start.
The Port motor also was a crank no attempt to start. Hit it with starting fluid still no attempt. Tried more starting fluid the next day, intitially just cranked and then fired.
Now starts with a click of a key. Runs great.
The vitals according to the Rinda scanner are identical on both motors.
Any ideas would be greatly appreciated.
Dont understand why the starboard motor wont fire. Verified spark at the plug.
Thank you
fountain38express is offline
