Vapor lock 350 MPI MAG's >
Old 06-24-2022 | 03:48 PM
Veteran: Army
Originally Posted by SabrToothSqrl
If you connect 2 return lines to 1 to return to the tank, is there a risk of gas being pushed from one engine, against the other? Not sure if it would become a problem, but thinking 1 line per engine return would be better.
just a thought.
A fuel pressure gauge would indicate if you had too little return flow capacity. If there was more fuel being delivered to the return line than the line could handle, it would tend to increase fuel pressure above the regulator setting.
DrFeelgood is offline
Old 06-26-2022 | 05:17 PM
I ended up buying the mercruiser kits to add the 2nd fuel pump and got them installed today. Going to do a test run tomorrow if the weather is good.
emspjay is offline
Old 07-06-2022 | 11:08 AM
Been out 4 times since installing the 2nd fuel pumps and so far so good.
emspjay is offline
