Finding 3M 5200/4200 locally >
Old 07-04-2022 | 04:37 PM
Default Finding 3M 5200/4200 locally
Went out yesterday to pick-up some 5200 for a quick repair. Can't find it in stock locally at any of the box stores (HD, Lowes, Walmart, Bass Pro, Dicks Sporting, auto parts stores,etc)
I usually buy it at the local Academy store but they put it on clearance a while back and none of the stores around here stock it. Sounds like they won't be stocking it in the future?
Anyone else finding it harder to get?
Ordered a couple of tubes online.
zz28zz is offline
Old 07-05-2022 | 04:37 PM
Yeah, like you I kind of counted on Academy Sports to have it...but they don't locally. Lowe's has the big tubes but who needs that since it cures quickly once opened. I ordered a couple of tubes of both 4200 and 5200 fast cure just to have "in case".
Baja 252 Islander
bajaman is offline
Old 07-05-2022 | 05:58 PM
Amazon
Keith Atlanta is offline
Old 07-05-2022 | 09:11 PM
Marine stores have it…west marine, marinas, mom and pops, etc
1MOSES1 is offline
Old 07-05-2022 | 11:53 PM
The marine stores either weren't open or were too busy to answer the phone on Saturday.
I'm surprised Academy no longer stocks 3M products..Used to buy the 3M upholstery cleaner/conditioner there too, but not any more apparently..
I would have purchased the big tube if Lowes had it in stock just to get back on the water.
Received 3 tubes of 5200 today from Amazon. Got 3 tubes of 4200 on the way. Time to start stockpiling consumables.
zz28zz is offline
Old 07-06-2022 | 12:14 PM
Wally's Avatar
Were doomed!
dont stock pile too much of it unless you plan on using it inside of 24month...thats the shelf life of it from time of shipment from the factory.....
-Wally
Wally is offline
Old 07-06-2022 | 11:00 PM
Yep, probably a lot shorter in a 100+ deg shop!!
Says on the tube that it should be stored under 77 degs so it will be staying in the house.
zz28zz is offline
Old 07-07-2022 | 07:13 AM
Around here Ace Hardware stocks the 5200
GLENAMY 242SS is offline
Old 07-07-2022 | 08:06 AM
SB
Here too, but not 4200. Same with our other hardware store. Too bad.
SB is online now
Old 07-08-2022 | 02:46 PM
TomZ's Avatar
Loctite PL series marine sealant should work if you can find it.
TomZ is offline
