Mercury wiring >
Mercury wiring
Mercury wiring
Old 07-08-2022 | 02:48 AM
Default Mercury wiring
Looking for help on wiring. I have been on the phone with mercury and they have been great help although no luck. I have the 14 pin wiring in my boat and motors that were installed are the old school 9 pin. So bought the adapters from mercury and it should work but I am not getting tach reading and oil pressure. I have checked all the wires and have no breaks everything ohms correct
gauges work. And sending units work but nothing is talking to each other.
I can’t be the only one that has done this any help would be great.
Jcltrucks is offline
Old 07-08-2022 | 07:21 AM
Been many that have had the same issue and don't know of one which posted the solution. I have the pin out which may help
AllDodge is offline
Old 07-12-2022 | 07:41 AM
You need this: https://www.greatlakesskipper.com/me...SABEgJ2-PD_BwE
I have a couple on the shelf if you don't mind used.
*EDIT*
I may have misunderstood your issue. What engines are you installing, and what gauges are in the boat?
Precision is offline
