Suddenly lost water pressure and got overheat alarm... >
Old 07-17-2022 | 06:43 PM
make sure you buy Merc or Q silver impellers not the knockoffs
https://www.ebay.com/itm/33271501529...cAAOSwCR9cnVV6
Yes, Quicksilver kit, not the $15 knock-off. Got it on Amazon though. It came today. Pump is together with new wear plates, Ran boat on the hose and it held 5 psi at idle which is about all the water my well and long hose can supply. Gonna try to splash it in the morning with fingers crossed. It's cheaper on eBay!
Originally Posted by zz28zz
If I'm following the progression of events correctly, you were on plane when you lost water press. Shutdown and got towed in. After it cooled, you restarted and got 5 psi at idle for a little bit then lost water press again. If that is correct, then maybe you ran over a plastic bag and it wrapped itself around the drive shutting off the water. Bag falls off while being towed in. When bag blocked water flow, it created a very high vacuum within the pump inlet hoses and caused the inner and outer plys to separate from each other within a short section of hose. Now when you restart at idle. The normal vacuum inside the hoses causes the delaminated inner hose ply to collapse and shut off water flow. Outside of hose looks fine. Just a WAG.. Not even sure if the hoses are 2 ply.
I've seen this happen with a vacuum hose once. Drove me nuts for hours.
That's not the sequence of events. It overheated and I shut it off. I was in no hurry to call the tow boat. I went in the water to check the inlet and it was clear. I waited til the engine cooled. Had a beer. Started it up and 5 psi and then down to zero with just a trickle flowing through the sea strainer. Did that a few times and then called TowBoatU.S. Had another beer. lol. I will keep in mind the possibility of an intake hose collapsing if it's not fixed though.
thirdchildhood is offline
Old 07-17-2022 | 06:57 PM
SABER28's Avatar
for whats its worth, i have the same hardin pumps as you and i have found they do not like even slight damage or even old/ stiff vanes. yours may have looked ok but i couldnt get a two year old one to suck water off the hose
the bag theory sounds quite plausible to me
SABER28 is offline
Old 07-18-2022 | 09:13 AM
No good. I had high hopes when it held 5-6 psi at the dock but when I planed out it never went over 5 psi. It's not a gauge problem. The headers were getting hot. The collapsing intake hose sounds like the next thing to look at. I assume the hose on the outside of the boat would be the more likely culprit? Either one looks like they will be a b*tch to replace.
Old 07-18-2022 | 09:59 AM
If you have the hard wall intake hose its not going to collapse. On plane water is being pushed into the holes on the drive. Not getting much flow I would suspect Bravoits or the intake transom hose is kinked
AllDodge is offline
Old 07-18-2022 | 10:10 AM
Yes, the hose in the engine room is very large and rigid. The one on the outside needs to flex and looks more like an automotive type cooling hose. I guess I will look into that today.
Old 07-18-2022 | 11:22 AM
Bravoits can be seen from the inside but need to remove the fitting that the hard wall hose attaches. This is one which the salt water has about closed it up completely
AllDodge is offline
Old 07-18-2022 | 12:02 PM
Fortunately this is a fresh water only boat that I bought new in 2005. Replacing either hose looks very difficult and it's guesswork. So the potential problem is the inner wall of the hose broken down and closing it off when water is flowing. Could I eliminate this potential problem by pulling the drive and putting a water hose on the intake end and opening the sea strainer and see if the flow stops or slows down? Backflushing indicates no blockage. Also, if there is no blockage, wouldn't the boat moving at a decent speed through the water create more than enough volume and pressure and at this point the raw water pump would actually serve to lower the pressure?
Old 07-18-2022 | 12:16 PM
F-2 Speedy's Avatar
Id hook a water hose to inlet side of the strainer to eliminate the aft hose and drive pickup, you dont have a fresh water flush ?
F-2 Speedy is offline
Old 07-18-2022 | 12:38 PM
Did you check circulating pump? Was there any rubber smell in the bilge or other indicators of circulating pump locked up? Would a bad thermostat lock up and prevent water flow inside the motor?
TexomaPowerboater is offline
Old 07-18-2022 | 02:02 PM
Found it! So glad I didn't have to change those hoses! Thanks for all the help.
