Mefi1 guys please HELP! 502 efi GenV problems with Mefi1 >
Old 07-22-2022 | 07:50 AM
Originally Posted by AllDodge
Being a MEFI 1 it might have a VST and should be using manual 16. Tell us more about the motor, VST or cool fuel, TB or EST ignition. With code 42 it should have EST
Okay I just looked up in my Manual #16, it says the same. 423 should have over 3000 ohms to ground, and when i trigger 424, 423 should drop the ohms to under 1000. My module does it the opposite way. except when I remove the ground wire of the EFI harness. then it will do it the right way.
AP700 is offline
Old 07-22-2022 | 07:54 AM
SB
Originally Posted by AP700
The distributor, I don't know what is what, so how can i identify? it is the distributor with the pick up coil and the ignition control module inside it. 2 connectors, the 4-pin is all for the ECU, Ref LOW, REF HI, BYPASS and IC. the 2-pin is + and "C" to the ignition coil.
Merc Est / gm voyager / gm late model external coil hei / etc, etc. Has lots of names
SB is offline
Old 07-22-2022 | 07:56 AM
yes should be this one. replaced the pick up coil ant the module serveral times. always used heat paste under the module.
AP700 is offline
Old 07-22-2022 | 07:59 AM
Yes it has the VST system. The distributor, I don't know what is what, so how can i identify? it is the distributor with the pick up coil and the ignition control module inside it. 2 connectors, the 4-pin is all for the ECU, Ref LOW, REF HI, BYPASS and IC. the 2-pin is + and "C" to the ignition coil.
It has EST ignition
Are you getting 5V on pin J2-24 Bypass?
Is there 5V reference at the MAP pin C and at TPS pin C?
AllDodge is offline
Old 07-22-2022 | 08:05 AM
SB
I would not continue to troubleshoot anything until a battery and alternator is put into service and there are still issues. . My 02.
SB is offline
Old 07-22-2022 | 08:09 AM
Agree
AllDodge is offline
Old 07-22-2022 | 09:08 AM
It has EST ignition
I have 5v on MAP and TPS. On J2-42 I have no 5V but let me check that twice.
AP700 is offline
Old 07-22-2022 | 09:09 AM
Okay I first install a battery. Alternator is charging when engine runs.
AP700 is offline
Old 07-22-2022 | 09:31 AM
Without 5V there, then the EST is not transferring timing to the ECM
When you say you have 5V on the others, is it exactly 5V or close to?
AllDodge is offline
Old 07-22-2022 | 09:44 AM
delete wrong post
AllDodge is offline
