Originally Posted by AllDodge
(Post 4839206)
Without 5V there, then the EST is not transferring timing to the ECM
When you say you have 5V on the others, is it exactly 5V or close to? |
okay i hookes it up to a battery, didnt change something. on tps and map i have 4.99V from the ecu coming.
on j2-23 i have 5000 ohms and 1000 ohms when i trigger j2-24, but only with ignition off. referring to the manual i should test that with ignition ON, but then I have 1000 ohms on j2-23 and 5000 when i trigger j2-24. so with ignition on it doesnt do what it should do.
how do you have the ignition switch wired into the cannon plug ?
https://cimg3.ibsrv.net/gimg/www.off...f6d0e9afd8.jpg |
(Post 4839218)
https://cimg3.ibsrv.net/gimg/www.off...f6d0e9afd8.jpg the right hand cable is connected to the battery negative, together with the big ground cable off the engine block. the lefthand cable is connected to the battery + together with the big cable from starter motor. |
4.99 is good enough
Circuit 423 should key ON = no more then 0.5V motor running = 1.2V Circuit 424 should key ON = no more then 0.5V motor running = 4.5V Did you get the module from GM or Merc? |
(Post 4839220)
4.99 is good enough
Circuit 423 should key ON = no more then 0.5V motor running = 1.2V Circuit 424 should key ON = no more then 0.5V motor running = 4.5V Did you get the module from GM or Merc? key on 423 is 0.00v on j2 connector without ecm hooked upstarting the engine isnt possible right now because i have disassembled the intake manofold to check the harness. i have 2 modules, thought maybe the 1st was bad. both are merc |
are you sure that gnd wire in the plug is in the correct pin ?
(Post 4839225)
refereing to this it should be right |
did try everything. don't know what to do now with this. anyone?
| All times are GMT -5. The time now is 01:28 AM. |
