-   -   Oil Block adaptor Issue (https://www.offshoreonly.com/forums/general-q/376641-oil-block-adaptor-issue.html)
Big_Baller 08-06-2022 03:15 PM
Just put on a Oil Block Adaptor from hardin marine on my gen5 454 and noticed that it was still able to swivel when fully tightened which I though was odd but attached my other oil fitting and went to prime the engine using my drill attachment. Once I started to build pressure I notice a gargling sound and sure enough it was pissing oil from the adaptor. So couple questions.
  1. I am not crazy in thinking this adaptor should not swivel once fully torqued down correct ?
  2. Anything similar out there that is not hardin marine that people have had good luck with?
https://www.hardin-marine.com/p-1459...en-56-bbc.aspx
underpsi68 08-06-2022 04:30 PM
Should not swivel. Is there in o-ring installed?
Big_Baller 08-06-2022 04:32 PM
yeah all three are installed, thanks for confirming the swivel part. Ill jump back on the boat tonight and see what i can find.
underpsi68 08-06-2022 05:05 PM
Check that the hold down bolt is not bottoming out.
Big_Baller 08-06-2022 05:10 PM
by hold down bolt i assume you mean the bolt that passes through the adaptor that should sandwich the adaptor to the block. If thats the case that what i was thinking is going on, bottoms out before engaging the oring to seal it to the block. But if thats the case, defective adaptor ? Or wrong fitting in block?
Big_Baller 08-06-2022 06:17 PM
Some pics to help…
the silver thru bolt on the adaptor is bottoming out on the fitting on the block before the oring seals. Thinking a block fitting with no ‘hex’ would be the thickness i would need.
https://cimg5.ibsrv.net/gimg/www.off...ac69aa603.jpeg
https://cimg6.ibsrv.net/gimg/www.off...5e9ce2cbe.jpeg
sutphen 30 08-06-2022 08:22 PM
is the adapter in the block have the same length of threads on both side?also,,are you running bypass valves?if not,you need to block off the pads opening.
Big_Baller 08-07-2022 03:08 PM
Thanks for the call on the bypass I havent given that ton of thought to the bypass but since I am using a hp6 filter and stand alone engine management I think forcing all oil through the oil is a better situation. Parts ordered, will post back once I have them.
-Nick
Rookie 08-07-2022 07:09 PM
-Nick
Plug it. All oil through the filter.
JMO
Big_Baller 08-08-2022 08:08 AM
JMO
yeah I ordered the block off kit, will be here Wednesday. hopefully this clears up my issue.
