Ready to kick this pos down the road…
#31
If both engines are doing the same thing I cannot imagine it being something in the distributors. Chances of both of them failing at the same time in the same way are pretty darn slim.
I would be going through the entire electrical system and checking all connections. Especially grounds. Take every thing off, wire brush the terminals and put it back together.
#32
Delco Voyager EST igniton
See last sentence of post 18.
Not sure if that applies to your setup or not but might explain no change in adv.
#33
I believe your idle circuit is too rich. I set my idle 13.7 and as much timing as I can. My new EFI setups needed me to up idle timing to 32° so it wouldn't stall during shift. I ran 2 different timing curves with those cams; locked 35° and 28°-36° High Idle on my Crane HI-6M's. I only netted 8° not the 10° it advertised, my light could have been off too.
I’ll need to baseline the transition slots again and this time actually try setting everything in gear.
#34
#36
GM Carbureted Engine Distributor Module 10482830
General Motors system. Used On: Marine Inboards w/ GM Engines. Replaces: Marine Power 0807-006M5, GM 10482830, 16139399, D1965A; Mercury Marine 811637, 811637T, 850487; OMC 3854003
I used a D1965A module years back on a carb’d boat and it worked fine. I can’t answer how thr more recents are.
#38
Thinking a couple of issues… carbs out of whack. And something odd with this distributor.
#39
#40
