Ready to kick this pos down the road… >
Ready to kick this pos down the road?
Old 08-20-2022 | 12:56 PM
  #51
Originally Posted by Twin O/B Sonic
For idle tuning/set up, I back the trailer in at the ramp and leave the boat strapped to the trailer.
Way easier/safer than at dock.
Done that a bunch of times if no other choice but on trailer is #1 pick.
Easier and safer really is determined by the ramp and or dock set up. For me, it would be 10x easier and safer tied in my dock slip.
Also, the angle of the boat on the trailer at a ramp may not be the same as it is at rest in the water. More angle will change the fuel bowl levels.
Griff is offline
Old 08-20-2022 | 09:05 PM
  #52
TomZ's Avatar
I’ll need to readjust the floats when I get her tied to the dock tomorrow morning. They were a little more raised on the trailer on land vs on the trailer at the ramp. Still some tweaking to do but getting there.
TomZ is offline
Old 08-20-2022 | 10:34 PM
  #53
Impressive perseverance Tom!
F14A water jet is offline
Old 08-21-2022 | 08:07 AM
  #54
Have you checked your rotor phasing?
fbc25el is offline
Old 08-21-2022 | 08:09 AM
  #55
seafordguy's Avatar
Should have bought my Cig Tom!!!! Hahaha
seafordguy is offline
Old 08-21-2022 | 08:22 AM
  #56
TomZ's Avatar
I have thought about that more than a few times, believe me.
TomZ is offline
Old 08-21-2022 | 08:24 AM
  #57
TomZ's Avatar
Have not but considering the rotor only fits or way and timing is the same as the other one and distributor position is identical, I think we’re good.
I replaced batteries yesterday… found one to be a little weak so I’m thinking that may have been a contributor, too.
TomZ is offline
Old 08-21-2022 | 12:45 PM
  #58
I would pull the valve covers and run all the valves, and make sure nothing is binding or having some other issue. Maybe leak it down too. A few valves hanging even just a tiny bit will make you chase your tail
sailtexas186548 is offline
Old 08-29-2022 | 07:47 PM
  #59
Saw the other thread, what solved your issue
Old 08-29-2022 | 09:33 PM
  #60
TomZ's Avatar
Couple of things…
The carburetors were full of ethanol powder. Also, found that one of the meter blocks was missing the mail well plugs (really Barry Grant/Demon/Holley??).
We also found that the batteries were a little weak. That may have caused issues with the ignition even though it was charging at 13.5-13.9 volts at idle. The port/#1 battery was the worse of the two (with the port engine acting the weirdest).
The carburetor issue really was the biggest pain in the ass. They were a real mess.
TomZ is offline
