Head size to match block bore?
Do heads need to be machine to the exact bore of the cylinder? I’m trying to determine whether certain heads are going to fit my 496 without any need for modification. I’m 060 over on the cylinder walls of the block.
No
Originally Posted by LakeHuronPower
(Post 4840842)
No
If you have a 2.19 intake valve most likely not.
No. But if your heads are set up for a bigger bore (many aftmkt heads comb chsmber are set up for 4.47” or 4.500 bore) make sure your headgaskets don’t over hang the heads combustion chamber.
Originally Posted by SB
(Post 4840873)
awesome! Thank you. |
| All times are GMT -5. The time now is 06:07 PM. |
