ITS transom assembly wire help >
Old 08-09-2022 | 05:59 PM
Default ITS transom assembly wire help
Looking for some help identifying some wire coming from my ITS transom. I believe that the two ring terminals go to my mercathod but need help with the 3pin red, white and blue plug.. assume trim and trim limit with power? Now I am running a stand alone engine management system so just need to know which wire is for what.
Thanks,
Nick
Big_Baller is offline
Old 08-09-2022 | 08:41 PM
That plugs into the engine harness for trim sending unit to display on smartcraft. There is not trim limit switch.
Unlimited jd is offline
Old 08-09-2022 | 09:23 PM
Do you happen to know the pin out? I assume one is 5v, sensor ground and signal?
