496 mag fluctuating Rpm , while going fast >
Old 08-19-2022 | 05:34 PM
Default 496 mag fluctuating Rpm , while going fast
Both motors run all day 3000-3400 rpm, if i hit the gas slowly bring it up around 4k. Port motor fluctuates rpm down and up rapidly like its bogging. But runs fine at slower speeds.
bobz71 is offline
Old 08-19-2022 | 05:43 PM
Rookie's Avatar
Fuel filter replaced?
Rookie is offline
Old 08-20-2022 | 07:25 AM
What's your serial number?
Might be a fuel restriction filter as Rookie mentioned, the anitsiphon valve, or weak fuel pump or boost pump (if there is one)
Put a pressure gauge on the fuel rail
AllDodge is offline
Old 08-20-2022 | 01:01 PM
Start with the basics. Change the spark plugs and fuel filter.
A friend had similar issues and replaced plugs and wires and all was good.
Griff is offline
Old 08-20-2022 | 05:32 PM
plugs and wires brand new and water separator filter, i will check fuel pressure at rail and while its running. thanks bob
bobz71 is offline
Old 08-23-2022 | 06:58 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I can't promise this is your issue, but Crankshaft Position Sensors on the 496s can present RPM fluctuation issues and not throw an error code.
Sydwayz is offline
