Oil bypass valve >
Oil bypass valve
Oil bypass valve
Old 09-12-2022 | 12:00 AM
Default Oil bypass valve
I'm running with the automotive version of the ZZ502 in my boat. The engine is fresh water cooled with aluminum heads. I did a parts swap from my older Mercruiser 454 but with the proper flywheel used on a 502. My oil pressure gauge reads 80lbs on start up. The block has a bypass valve as does the remote filter adaptor. Should I remove the bypass valve from the block? With a high pressure pump, what psi valve should I use?
Thanks in advance!
BravoX1D is offline
Old 09-12-2022 | 12:59 PM
Some people remove the valve in the block (filter pad) and put a plug in there, others run the valve. If you do run the valve be sure to put a 30psi one in there. Typical automotive applications use an 11psi valve and you will lose an engine real quick with that!
87MirageIntruder is offline
Old 09-12-2022 | 03:02 PM
SB
Bypass valves (actually called filter bypass valves) work off of pressure differential. Not the psi you see on the gauge.
SB is offline
Old 09-13-2022 | 06:15 AM
and don't forget to take the valve out from under the oil filter nipple.
sutphen 30 is offline
Old 09-14-2022 | 09:09 AM
TomZ's Avatar
I run the 30 lbs valve in the filter pad and removed it from the under the filter head nipple. I didn't use a plug because I didn't like how the ones I had fit so just went with the correct valves.
TomZ is offline
Old 09-16-2022 | 01:27 PM
If I have it right, I've heard tell that the valve above the filter nipple is associated with using an automotive type oil cooler. That it is actually a good thing because it prevents oil drain back from the oil galley. It's all very confusing! I will go with a 30lb valve in the Mercruiser adapter as it was the original setup. I have been around engines for many years, but only recently learned of the valve used in the filter pad. Who knew?
BravoX1D is offline
Old 09-16-2022 | 02:15 PM
SB
Arcticfriends wrote ‘the bible’ on oiling issues with the 454/502 systems. It is referred to all iver the net.
click: oil pressure problems from stock hardware
SB is offline
Old 09-19-2022 | 11:50 PM
I actually meant the valve above the filter threads, not the pad. Duh!
BravoX1D is offline
