HP vs Prop/ RPM
HP vs Prop/ RPM
If everything stays the same except added HP, how many RPM would be gained from 100hp gain? For conversation sake the peak HP is in the same relative rpm range or slightly higher.
GENERALLY speaking, about 500 rpm...
Baja 252 Islander
Baja 252 Islander
Griff (09-19-2022)
If you are looking to see how much more prop you might need I would first run the new motor with the original/existing prop. Yes you may need more prop but sometimes not. You just turn the existing prop faster. Get a solid baseline first. THEN prop shop if needed.
The following 3 users liked this post by Trash:
I’ve always propped for close to peak hp + - If slightly higher I didn’t care due to trim/tab water conditions. No need to load the engines more than you have to. I’m in the same boat only I started out of the gates with all new everything except props that came with boat. I need to down size as I’m only pulling 5,300 max. Still pull extremely hard in mid range for an old 40 straight bottom but giving up top end speed. I’m searching for 2 pitch sizes smaller trying to achieve 5,900-6,000
Where you want to cruise is also a factor. My plans for my Formula 233 project, are a 21p prop. 30 mph slow cruise around 2600rpm. Fast cruise at 40 mph, 3500 rpm. Max rpm 5600 ish, at 65mph. 13% slip.
This way my slow cruise has the BBC turn relatively slow, and still lots of vacuum at the 40 mph fast cruise. All without lugging the engine, but keeping rpm in check.
23p would put it at 2375 rpm at 30 mph. Probably too low, certainly with any weight in the hull. 30mph in rough water needs a good easy prop to push feathering the throttle.
I added about 60 ish hp to a 454 mag in a 24 Outlaw and gained 400rpms.
It really will depend on your HP starting point also. If you add a 100 hp to an 800HP engine, your rpm gains will be less than if you add it to 400hp engine
The following 3 users liked this post by Griff:
The previous owner of my 12 m had blown 468 b&m 250’s. He only turned 4,400. My NA 565’s turn them 5,300. I didn’t think I’d even see that and was on a rampage to get other props. Although I do need I’m glad I just stayed with what I had to gauge what I need. And I’m not done chasing power either.
IMO… as others just ck it out as is. I hate lazy boats even if tip end speed is the same.
Going by the 500rpm /100hp I'd be picking up 1300 rpm. I really don't plan on ever spinning it to 6k. Not that it wouldn't be capable with all forged internals. Goes back to wanting it to live a long time.
