1990 454 mag lost power >
Old 10-16-2022 | 10:30 AM
Originally Posted by Prestigeworldwideee
Guessing my next move to replace the distributor and rotor?
Look like the one I should buy?:
A.A Tune-Up Kit Distributor Cap Rotor for MerCruiser GM V8 Thunderbolt IV, V, HEI Ignition System 18-5273, 805759Q3 https://a.co/d/iQcMcER
Im guessing your next move is to slow down and develop some trouble shooting skills. A harbor freight test light goes a long ways and they start at like $3.99
https://www.electricaltechnology.org...lor-codes.html
phragle is offline
Old 10-16-2022 | 10:49 AM
GPM
Maybe,
Amazon.com: B. Ignition Sensor Kit for MerCruiser Thunderbolt I IV Distributor : Automotive Amazon.com: B. Ignition Sensor Kit for MerCruiser Thunderbolt I IV Distributor : Automotive
GPM is offline
Old 10-16-2022 | 12:02 PM
Originally Posted by GPM
Could be the module in the distributor
How do I test that? Pop the distributor cap off, use a light tester and the battery negative?
Prestigeworldwideee is offline
Old 10-16-2022 | 12:56 PM
TB IV ignition troubleshooting flow chart https://bpi.ebasicpower.com/faq/MERCSB92-11.htm
Griff is offline
Old 10-16-2022 | 01:07 PM
I don’t have many diagnostic skills, there’s a spark on the outside of the distributor cap that connects to the ignition module. I tried touching my light testers to everything inside the distributor cap and got nothing.
Old 10-16-2022 | 02:36 PM
SB
Okay.
turn key to run. Put your volt meter to the ignition coil leads. Is there 12 volts present ?
SB is offline
Old 10-16-2022 | 04:02 PM
GPM
From the looks of that distributor, you may want to replace it.
GPM is offline
Old 10-16-2022 | 04:07 PM
Originally Posted by SB
Okay.
Just pull a spark plug wire off and crank it over?
Old 10-16-2022 | 04:48 PM
GPM
You already know you don't have spark, you just don't know why. Call your local auto parts store and see if they can test your module.
GPM is offline
Old 10-16-2022 | 05:07 PM
SB
Okay.
Please reread above.
Furthermore….your coil looks like this.
Looking at carburetor from frt of engine, it is just behind the carb to the right.Puple wire terminal is + and grey wire terminal side is -.
SB is offline
