-   -   Mercury 409 MPI (https://www.offshoreonly.com/forums/general-q/377405-mercury-409-mpi.html)
AllDodge 10-17-2022 06:53 PM
Originally Posted by underpsi68 (Post 4848436)
How much torque does it make since it is being compared to the 8.1?
it lust 650 at 3600 rpm
underpsi68 10-17-2022 07:04 PM
The new 409?
JaayTeee 10-17-2022 07:06 PM
Is this a GM small block or the Merc produced piece that replaced it sometime around 2015?
compedgemarine 10-17-2022 07:23 PM
I am sure this is an all in house Mercury block, etc. so that when you have an issue you get to buy parts from Merc for 10 times the cost of normal sbc parts.
DrFeelgood 10-17-2022 07:25 PM
I think pretty much all of Merc's current offerings are in-house, likely for that exact reason.
SB 10-17-2022 08:36 PM
Says needs gears changed in outdrive, therefore not near as much.
would be cool if they mention cubic inch and other particulars. Just mosrky marketing ‘hype ‘ terms at this point.
Not that it matters i guess because way too much money for the end result.
Really seems they hate inboards and i/o’s and wanna just churn out outboards. IMHO
F-2 Speedy 10-17-2022 08:47 PM
Pretty sure I could build 2 650 hp BBC for the asking price......:D
cheech 10-18-2022 10:27 AM
My guess is it is the MERC produced. Link below says 4.035" bore and 4" stroke. So sort of usual Gen 1 small block combination.
Which the new 2015 up MERC 6.2 seems to be a near identical copy of.
409 Spec Sheet
Originally Posted by underpsi68 (Post 4848441)
The new 409?
He had to mean the LT4.
I didn't find any dyno charts or torque specs on the new Quicksilver 409.
Because if the 409 makes 650 lb-ft at 3600??
We definitely need to see that.
Originally Posted by techman (Post 4848412)
I also noticed that the Quicksilver 8.1 and the 540 Mag stroker are no longer available. Looks like this is your Mercury sourced replacement for big blocks with a warranty.
In Quicksilver yes.
Mercury still has the 8.2L/502 in³.
Uncertain if they'll sell those for repower or not?
hogie roll 10-18-2022 10:47 AM
Originally Posted by Mbam (Post 4848405)
Performance 400 horsepower 5000-5800 RPM Exotic idle quality Great acceleration Flat-plane crankshaft 150# lighter than 8.1L Speed gains with Bravo One X
Technology ECM 555 SmartCraft 10-pin harness Engine Guardian MPI fuel injection Mechanical throttle & shift
Black-X valves Dry joint iron exhaust Heavy-Duty iron block Forged crank, pistons & rods Shaft-mounted roller valvetrain Full System Fresh Water Cooling Heavy-Duty Eng. oil & PS fluid coolers
Single-point water drain 3-year limited warranty 25W-50 engine oil Long-life coolant Remote oil filter 87 octane fuel
985 pounds. List price $33,425, available next month.
Can you sell just crank? Or the whole bottom end? Price?
PA.WOODCHUCK 10-18-2022 10:47 AM
Is it any cheaper for flat plane crank engine to be built by mercury or others?
