oil leak on new rebuild >
Old 10-21-2022 | 08:31 PM
Originally Posted by 35fountain
So today I went down to the boat at the Marina and I got into the right side of the engine, reached all the way down to the bottom of the bellhousing...wow oil at the flywheel cover. This is the 1st time I noticed this. Rear main seal now?. He installed felpro rear main seals the blue ones. Unless the guy put them in backwards? So I checked the oil level and it was only down maybe 1/8 of a quart @ 1 hour run time
Is it possible that that breakin crankcase pressure blow by caused the pan gasket to open and let out oil in the back corner of the engine. Windage shooting oil onto the flywheel because it seems like the oil leak is getting less. My total hours are 12. Maybe there was a lot of blow by in the beginning and now the rings and everything finally seated.
Very doubtful. Very very doubtful. If you had that kind of blowby it would still have excessive blowby. He said he put silicone on the one piece gasket in the corners. Most likely why it leaks.
Smitty275 is offline
Old 10-21-2022 | 11:00 PM
TomZ's Avatar
I used the Felpro 1-piece gasket and the instructions said to use a spot of sealant at the transition corners (rear seal housing, GEN VI, and the timing cover).
TomZ is offline
Old 10-22-2022 | 07:26 AM
35fountain's Avatar
I really don't know what he did. I wasn't there watching him. It looks like there is sealant on the pan by he front timing chain cover. No leak there and very difficult to check the rear. I am amazed I got to the lower bell housing. We will soon find out. The machine shop guy has been in business for 55 years, Boat engines, auto engines, Ferrari engines, Jaguars and many others. He has done other engines for me with no issues. He had these engines for 2.5 months. I lost 3/4 of my summer. Just my luck...Now back to square one.. Engines out again.
Big question. AT WHOS EXPENSE?
35fountain is offline
Old 10-22-2022 | 07:40 AM
SB
I wouldn’t say square one. You’re original square one was a horrible mess. Just putting a positive on this. :wink
SB is offline
Old 10-22-2022 | 08:14 AM
35fountain's Avatar
Originally Posted by BillK
Yuk, I have heard mixed results on the one pc oil pan gaskets. I have not had an issue with them but some guys do. I have been using the Fel Pro ones. One of my friends at another machine shop has started smoke testing every engine right on the stand. Thinking about getting a smoke machine and doing the same thing. Running them on the dyno every time would probably catch little things too.
I agree about the Dyno but he sold his years ago.
Old 10-22-2022 | 08:16 AM
35fountain's Avatar
Well he is coming to my place to check the engines and probably fix whatever needs to be done. But getting the forklift and someone to help me get these out "Costs"
Old 10-22-2022 | 02:33 PM
35fountain's Avatar
Blue is dye color port
Dye is blue color port
Dye is blue color. Port
Blue is dye color. Port motor
Old 10-22-2022 | 02:35 PM
35fountain's Avatar
And to top all this off a small leak on remote oil filter adapter of starboard motor. I changed both gaskets.
Blue is dye color
Old 10-26-2022 | 01:34 PM
35fountain's Avatar
Default Dye pics posted
Blue is dye. If it was the rear main seal I don't think it would show on the flywheel cover??
Old 10-26-2022 | 02:05 PM
Veteran: Army
It looks like there's blue along the oil pan mounting rail/bottom of the block?
I don't see any alternative to pulling this motor out.
DrFeelgood is offline
