Edelbrock Pro-Flo XT EFI system BBC in a marine application
#31
Don't give up on the MPI intake, it can actually support more HP than the 500/525 style. MPI will make more torque than anything on the market but won't go much past 5600 rpm for peak power. Articfriends(Smitty) is now enlarging these stock throttle bodies and that does make a pretty good bolt-on difference. Also let him school you on the flame arrestors, that plastic one you have is absolutely terrible and kills HP. He has made over 700 hp with a low CR 548 with a modified MPI intake.
Also, you probably have MEFI3? I'd just stick with that and save a couple grand versus going with Holley. It can be re-tuned and is more than capable for your plans.
One big thing if you like to run at high RPM for extended periods of time, the factory oil system sucks and kills oil PSI. Change block adapter, filter head, cooler, and go to -10 lines at a minimum and you will see another 20 psi oil pressure with no other changes. Couldn't believe the difference on mine, I was about to rebuild them for being tired as hot oil psi was getting close to 32 psi max, now it doesn't go below 50 psi.
It is 100% a MEF-1 ECU so it has to go, trust me I would love to save a few K but I think alot of my issues are this ECU.
As for the intake I would love to just upgrade the injectors, keep the stock intake and toss Holley at it.
#32
I want to go with a better remote oil filter/cooler setup I kinda figured the stock one is not the greatest. I am on a small lake so it is never at high RPM for more than a min or two at best but still I want to do whatever will make the engine happier. What did you go with for a cooler?
I went with a 3"x18" (Teague) cooler mounted above the bellhousing, -10 AN lines, Improved Racing thermostatic oil filter head, and new billet block adapter (rest from Summit).
Where are you located?
#33
MEFI 1 can even do what you want. It just can't deal with boost all that well. Injectors are a PITA for alternatives with that intake because they are Honda-Kehin style injectors - not impossible, just not an easy bosch/delco crossover. Get them from a good source and flow matched, lots of Chinese copy junk that will burn down your motor out there. You can have your stock ones cleaned and flowed, go with adjustable regulator, crank fuel psi up to 60 psi, and support your power goals still.
When I pulled he rail the injectors have these black caps look like an adapter as the opening in the manifold is way to big for the injector so they added these adapters. To me this is juat another source of a fuel leak??
I will look into the parts you listed for the oil cooler, as for making -AN lines I have made way more in my time that I ever wanted too LOL I am a fan of Russell line and fittings.
#34
Putnam County within NY state. Boat lives on lake Mahopac.
#35
1) You have an ECM that works
2) Wiring harness works
3) Ignition system etc already tied in
4) MEFI 1, in spite of being the oldest version, is the easiest to tune (other than lacking fidelity in the fuel table)
5) You don't have to spend thousands on a new intake, ECM, wiring harness etc.
IF you are going with any boosted application, then yes, ditch MEFI 1, but that does not sound like the case.
As far as injectors verify the ones you have and their flow rate. They may be able to handle the HP you are targeting without blowing through the duty cycle. If you need higher flowing Keihin I have had luck with RC Injection in Torrance, CA. Not affiliated but they got me what I needed.
PM if you want to chat as I have done something similar to what you are doing with a MEFI 1 and would take pages to type out.
#37
#38
I don't mind spending the extra cash on Holley if it makes life much easier, just need to do a few extra side jobs lol. I just dont want to be stuck fiddling around with an antiquated system fumbling around to find out I need to upgrade anyway. Plus if I ever did decide I want to toss the kitchen sink at it and feed it all the BOOST I know the EFI is already there.
#39
Use MEFI Burn to download the existing factory .bin file
Save this file in multiple copies.
Use TunerPro and open up a copy of your factory tune to dive into the fuel and spark tables.
Save this as a NEW file (don't overwrite the original).
Use MEFI Burn to upload the new tune to the MEFI 1. Takes about 3-5 seconds. Must be done with KOEO. No live updates while the motor is running. One of the downsides of MEFI 1 but not insurmountable.
The VAST majority of the scalars, constants, and flags shown in TunerPro for a MEFI 1 .bin file are actually not implemented nor used, so they do add some confusion for those looking at it for the first time.
Yes wideband is a must.
#40
I was going to run a 525 intake but I was told it has special injectors so I bailed plus the guy I was buying it from was jerking me around. I just want SIMPLE, im not looking to stop the world with this thing just want some fun reliable power. I know (fun, reliable & boat) do not belong in the same sentence!! Im thinking the XT with Holley HP would be a kick ass setup but now the TB clearance issue on the stat housing and the manufacture lead-time nonsense can be an issue.
Speedway motors says it ships by 11/29/22 but I am going to call and see how realistic that is or if it is total BS to get the hook set then drag you through the water of WAITING for months on end. Winter is long but not that long!!
I curious how I will adapt the throttle linkage to the Edelbrock cable style TB linkage??
A 525 uses the same EXACT injectors as a mefi1 454/502. I have found a 55lb import injector that I sell as match flowed sets, its slightly shorter so I machine bottom spacers to ensure it is in rail enough BUT your stock honda/keihan factory ev-1 connector injectors IF they flow fine will be just fine, I wouldn't change them unless when cleaned and flow tested they are terrible. I flow and clean alot of early 454/502 injectors and 525 injectors at my shop and for most part they clean up and flow fine.
Injector SIZE : your stock injectors are 48 lb, 48 x 8 is 384 lbs per hr at 3 bar (43.5 psi). 384 x 2 =768 , if your bsfc was .500 that means they would support 768 hp, assuming your bsfc is closer to .58 which is typical of mpi engines I tune and dyno you can deduct 16% from the 768 which would still get you to 645 hp maxed out. Even at 80% of that, it will get you over 500.
Stock fuel pump: stock fuel pump is 190 lph, its done at about 560 to 580 ft lbs tq/hp before injectors are.
Upgrade fuel pump/efi regulator /fuel cooler lines: IF your going to aim for more hp than stock fuel pump can supply and you upgrade it, you can got from 3 bar/43.5 psi to 4 bar/58 psi.
58 psi will increase the flow of your injectors by 15%, that 15% will take your max hp easily to 600 hp at 80% duty ccyle/.58 bsfc. I have pushed stock injectors close to 100% duty cycle over 675 hp with no issues.
Wideband/02 sensors somewhere in your current exhaust: If you do ANY mods, regardless of intake, etc, a wide band 02 sensor somewhere in your exhaust that you make tuning decisions from will keep you from running pig rich somewhere OR making pretty little piston ashtray gifts for your smoking friends!
Mpi Intake: I have made well over 600 hp/600 ft lbs of tq with mercruiser black intake by cutting down runners even with plenum floor/boring out TB and making 67 mm blades vs stock 60.
Flame arrestor: The flat plate gen 6 FA is a restrictive hp killer on modded engines
the Gen 5 mefi 1 factory fa is BEST flowing factory piece, those aluminum necked down adapters with clamp on KN fa's from various suppliers flow WORSE than stock and kill massive hp on modded engines
In recent testing I found the Gaffrig oval FA is by far the very best
Throttle linkage on edelbrock proflow (assuming you could actually get one), You put a throttle post thru side of their curved lever and make a bracket to bolt on side of intake, Ill post up a pic if I can find one.
Your boat in picture: Since its a single and doesnt appear to have sufficient room to put a large enough FA on the proflow, I wouldn't even consider it. A 90 KILLS a bunch of the hp gain that its known for. A proflow will embarrass a vic jr with a modded tb and good air flow but most that gain will evaporate if you clamp any 90 onto it. A merc mpi long runner intake will beat both a vic jr and proflow in early tq due to runner length at expense of top end hp but singles unless they are really a fast, stepped hull need square tq/hp. Guys get caught up on peak hp numbers that come from big cams, short runner intakes that sacrifice torque. Then boat sucks to drive, wont pull no prop. wont get on plane loaded down etc. If I think of anything else to ad I will, Smitty
