Edelbrock Pro-Flo XT EFI system BBC in a marine application
#51
OK that is the most in-depth write up hitting every question I could have SO THANK YOU!!!!!!
1. Injectors, can I send my stock injectors to you to be flowed and confirm they are up to the task, again im shooting for 550Hp anything more is just a bonus
2. TB, do you modify them to the larger 67mm butterfly's?
3. The cool fuel, setup what do you suggest I swap it out too and I was planning to go return style when I install a new aftermarket regulator like a magnafuel
4. do you have a Part# for the Gaffrig oval FA?
5. I want to run Holley HP on the boat and will be installing a Wideband, do I leave it in consistently on closed loop or tune then run open loop?
6. O2 location, I am debating to go dry tip or not because I kind of do not want to loose my silent choice exhaust as the lake im on break balls for noise, if I keep the full wet exhaust whats your recommendation for O2 placement? Also run two I assume?
7. What is your opinion on keeping the stock cast irion rectangle port heads over going to an aluminum? I am not closed loop cooling but am in fresh water.
https://www.ebay.com/itm/12367585652...3ABFBMloPAppNh
https://www.ebay.com/itm/14315951777...3ABFBMloPAppNh
Anyone see these intakes on ebay?
Again thank you again Smitty for the detailed writeup!!!!
You can PM me on the modded tb and injector stuff, I don't want to get banned for skirting the forum rules which I may already be doing even mentioning the work I do although I am at least a paying member.
as far as the fuel system, all of the merc stuff is strange inverted flair, to upgrade it you need to change EVERYTHING except stock water separator filter housing.
You would buy a holley 750 efi pump or a a-a1000, put it on a relay triggered by the original efi relay as it was never intended to supply uch more than a stock 6, 7 amp pump. You would tap rail where stock fitting goes in, buy a efi regulator, a auxiliary fuel cooler , a 10 micron filter after everything and then -8 and -6 hoses, hose ends, adapters etc. However, IF your hp goal is 550, as long as your stock stuff is in good working order, it will be fine and save you quite alot of money.
Flame arrestor: https://gaffrigperformance.com/102-EFI-Flame-Arrestors
Its a beautiful, high flowing piece but you will also need to buy (4) 35$ studs from them or find some gen V FA/tb studs as its impossible to mount correctly without them.
O2 bung: if using stock cast manifolds, you can buy or make a 02 plate to sandwich in riser but it is very hard and cobbled looking to move riser up 1" and still have silent choice connected to it.
A nice alternative I just did on a stock riser in my machine shop was install THIS piece: https://howellefi.com/product/adapto...or-marine-use/
You could run (1) o2 on the 2/4/6/8 side and be fine, IF you buy a holley terminator, it will only run one anyways.
02 longevity: That bung in a riser along with a innovate 3729 to help keep moisture off 02 sensor would make it work the best but I would prob STILL get it dialed in then remove and plug it.
Good aluminum heads along with intake/tb mods and cam will get most 502s to the 600 to 620 hp range from the 550/560 range with ok cam and iron heads, the heads are typically worth 50 to 60 hp as long as you take advantage of the extra flow with right size cam and usually aftermarket exhaust, Smitty
#52
https://www.mcmaster.com/90575A276/
#54
Those are 500/525 castings, with less plenum volume they offer no real power advantage over a 502 mag intake with simple mods and bored out TB other than possibly a peak hp rpm gain from slightly shorter runner, the fact you would have to come up with rails, throttle body and the rest of the missing pieces, I wouldn't waste my money.
https://www.amazon.com/Innovate-Moto...56991661&psc=1
I spoke with Holley and I cant run Terminator X as it is not Coastguard approved and as moisture resistant like HP due to no encapsulated ECU on X like HP.
Fueling I have heard horror stories about the "cool fuel" and getting to it once the engine is in the boat looks to be a REAL PITA so I may prefer to spend the extra money and upgrade the system to a good quality pump and regulator. Sorry for the 50 questions but do you have a recommendation for a fuel cooler I assume remaining water cooled?
I will PM you about the TB & injectors.
#58
When I put the Gen V flame arrestors on my Gen VI 502 MPIs, I bought threaded rod from McMaster and cut a couple inches off. I think the final length was about 8 inches each. 316 Stainless for $4 each.
#59
The proflow front mounted tb intake with some tb work is a great piece itself, it will make outstanding hp and slightly better tq than any open plenum intake on a typical 502 build with marine cam. The software sucks, I would buy just the intake and use holley.
a couple things to note though: , no one has had these intakes in stock for sale for well over a year so that's a consideration, that delivery date of may 2023 has been moving since 2021.
Flame arrestor /entry of throttle body: to get most out of that intake, a very good cone filter with a entry taper device is very crucial. The last engine I dynoed and tuned with one, I tested countless cone filters, volutes, etc. a brief synopsis is this: 515 (4.530 bore 502) was making around 650 hp with the proflow, that hat hp dropped to the 620 range with most clamp on cone filters. It went to the 680 hp range with a volute clamped on TB and barely had a hp drop with a 10" cone clamped to that volute. Its very difficult to get a thermostat housing under it, it can be done by clearencing the bottom of TB itself. Forward clearance in your boat is a consideration too, IF you have to put a 90 on the tb, you'll kill the power and it will never make its full potential so you'd really need 11 or 12 " in front of tb to use a non restrictive filter, Smitty
#60
My plan is your plan almost exactly but looks like I am going to either adapt Holley HP to the stock MPI intake or go with multi-port throttle body style injection system.
