Marine Machine steering fittings
Hi, does somebody know from where to source stainless fittings to M&M hydraulic steering? Any shops to get these from south FL, between Miami - Ft Lauderdale? Thanks
https://cimg1.ibsrv.net/gimg/www.off...55727316fb.png |
Latham should have them . They are in that area .
Hmm.. Tried ordering these from cpperformance, they carry Latham fitting and said they don't have right ones for M&M.
I will try Latham anyway, thank's |
I had new hoses made for mine - Parker. They were expensive.
Could always check with Sick Stinger. He might have some hoses where you can salvage the fittings. You'll need the proper mandrel to attach the fitting to the hose. |
The MM fittings are not Stainless. They are SS or nickle plated brass. Brass seals better. They are also reuseable and I reused mine. Kind of a pain to get the old hose out, but applying some heat helps. You don't need any special tools. The hose literally screws onto the inner part of the fitting.
CP only sells the brass -6 JIC ones. Teague sells the SS fittings which are an IMCO part https://teaguecustommarine.com/hyd-s...parts-fittings |
I used to get all that stuff from aeroquip in Ft. Lauderdale. if they didnt have it they could get it.
Good info, thank you. I was stupid enough to throw the old ones away since they had some corrosion..
Originally Posted by DoubleH
(Post 4852329)
| All times are GMT -5. The time now is 06:06 PM. |
