Measuring driveline centers on twins
How accurate is the grease fitting on the upper steering pin to measure driveline centerlines?
Imco steering has the unimount transom bracket that is in 1/2” increments - 34.5” up to 36”. Seems pretty crucial to get it right for geometry purposes.
What is the best way to measure? Motors are out and drives are off.
I did this install on my Formula 292. You'll love it. I measured with my drive and engine still in place... but I'll try to help.
With the drives on, I measured center of driveshaft to driveshaft of the props. Also measured center center of my saddle mount steering pins (is yours a saddle mount like mine was?) you can most likely measure this, assuming it's center to center. I also measured skeg to skeg. (I wanted to measure everything I could 10x because no one wants to drill wrong holes through a transom)!
You could measure transom housing to transom housing inside, and add 1/2 the width on each side.
Here was my install:
IMCO Uni Mount Steering Install - 292 FasTech
if you need any tips. let me know. also. boats on a trailer MAY NOT BE LEVEL. Do not take level for granted.
The install must be 'flat' with the boat. which may not be flat w/the earth/trailer. Mine measured quite level for my install. but looking back if I stuck a level on the boat and it wasn't. I might have just let air out of one side until the boat was flat for the install. make things easier. Always measure 10x. drill once
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Thanks for the replies!
The grease fittings and trim line manifold were same measurement.
SabrtoothSqrl - My 25' Checkmate had Latham steering when I bought it and I would not own a performance boat with out it now. I even talked my dad into putting hydro steering on his pontoon.
