Going from 12% underdriven to 1 to 1. What to do on carb jetting >
Old 12-27-2022 | 02:16 PM
Default Going from 12% underdriven to 1 to 1. What to do on carb jetting
Hey guys. I have.a 500ci bbc with an 8/71 blower. Want to go from 12% underdriven to 1 to 1. What should I do with the jetting when I make the pulley change? Thanks in advance for any info. It’s in a 48 Anglia street car
iliveonanisland is offline
Old 12-27-2022 | 03:32 PM
Thats not a question anyone can answer over the internet.
Make your change put an AFR meter on it and adjust accordingly like everyone else .
ICDEDPPL is offline
Old 12-27-2022 | 09:23 PM
I was hoping there was a golden rule like more boost equals x quantity of more fuel lol. Tell me about the AFR meter. Is that a better way to tune compared to reading egt’s? Thanks for any info
Old 12-28-2022 | 08:59 PM
Your drawing thru the carbs so they should be close. With the increase in cylinder pressure your going to need to pull timing. Hard to tell how much.
Smitty275 is offline
Old 12-29-2022 | 08:11 AM
https://www.innovatemotorsports.com
hogie roll is offline
Old 12-29-2022 | 08:30 AM
If your initial jetting is close, it shouldn't change much by adding a little boost as long as your fuel system all of the way to the needles/seats is up to the task. You will have to install some O2 sensors to know for sure.
As far as timing, the last 2 blower boat engines that I did, I used the Daytona ignitions at 35 deg timing and I pulled 1 degree of timing per # of boost starting at 4500rpm. It worked well in the boats, but may not be necessary in a car.
snapmorgan is offline
Old 12-29-2022 | 12:31 PM
I will check the timing to see where it is the next time I fire it up. I am buying an AFR meter system now with data logger so I can see what it’s doing when driven. Thanks.
Old 01-20-2023 | 04:56 PM
the Anglia doesn’t weigh much I’m sure it’s under 2k lbs. so isn’t loading the engine like a boat I might install a knock sensor as well to be sure I don’t hurt anything. Thanks for the info, rm
