Mercury 496 Build- Exhaust/Camshaft Reversion
Sorry I didn't know that, thought they were the same bolt pattern. I did see this, Hardin Marine - Big Block Chevy Mercruiser 496 / 8.1L / 8.2L Exhaust Systems (hardin-marine.com)
They will bolt up but may be a little narrower that the 496 pipes. You should be able to make the tailpipes work with a hump hose (you’ll still need tailpipes… could have them made with the correct fit - contact CMI).
I dont know if its true or not but I was told regular 454/502 manifolds would bolt up fine to the 496. The only difference is that the 496 manifolds have a water provision on them and a manifold company could add that. Might be another option.
Im in sort of the same boat here, I am freshening up my 502 that popped a head gasket bored it out to a 509. want go with a little more cam so I have to lose the silent choice exhaust, I have EMI thunder manifolds and cast risers so Im to switching to SS risers that don't mix until it gets to the transom. Does it become a lot louder this way?
The further away from engine you mix the water, the louder it gets.
I am running the HO525 203 cam. Think 731 specs. The HO600 206 cam think 741 spec. You definitely want the better exhaust with the 206 cam. Stock exhaust is likely to revert with the 206 cam. Hence Larry moving you toward the stock exhaust friendly 203 cam.
The Dana Marine exhaust made 553hp with 203 cam. Stock exhaust was 530hp.
Run the 206 cam. Modify your stock risers like mine. Upgrade in future.
Follow my recipe.....3" stainless extensions welded onto the stock 496 risers. Mine were 12.5" long. Water mixes with exhaust at transom. If you are running rubber exhaust hose make sure extensions do not touch the rubber.
More info on your setup. Heads? Intake?
