-   -   dynoing with FULL wet exhaust?? (https://www.offshoreonly.com/forums/general-q/378250-dynoing-full-wet-exhaust.html)
BBYSTWY 01-30-2023 01:00 PM
My thought is as big of a tank as you can fit behind the dyno, then run flex pipe or softwall rubber exhaust hose through the upper portion of the tank above the water line, then install a large "squirrelcage" fan/blower in the top of the tank and vent outside. This should take all the fumes out and keep the water in. Then simply run a valve/ fitting at the top of the tank that will run up and feed the sea pump. I would be concerned with the water heating up quickly that's why I would say build the tank as large as possible. I would also run a large line with as much pressure and volume from your water supply to the building into the tank and run a drain off the tank to the outside right above the stagnant water line. This will allow fresh water to run in the tank while you are running with the hot water hopefully running out of the drain. Obviously you probably won't move enough through it to keep it cool for hours but I would think it would be enough to cool it for a few good pulls? I'll draw something up to illustrate what I'm trying to explain lol.
ThisIsLivin 01-30-2023 01:03 PM
Smitty, I have heard that Tyler Crockett runs wet exhaust on his dyno. Maybe you can run over and check his setup out.
BBYSTWY 01-30-2023 01:09 PM
https://cimg4.ibsrv.net/gimg/www.off...c650a35ea7.png
Obviously pretty crude but a quick paint project to help explain what I'm talking about hahaha
SB 01-30-2023 01:26 PM
I'd run the exhaust water across and under the st into a shallow pool and watch all the fine ladies in the winter get into Smitty's Hot Springs.
Just a thought. (.) (.) I mean :)
Brad Christy 01-30-2023 02:26 PM
SB,
I like you more and more every day. :ernaehrung004:
Thanks. Brad.
(937)545-8991
DrFeelgood 01-30-2023 02:33 PM
Smitty's Titties! Adults only Heated Pool!
RBeyer 01-30-2023 07:50 PM
Originally Posted by articfriends (Post 4857778)
any fellow engine builders who dyno marine engines on here running full wet exhaust? Im building a new dyno room and trying to figure out HOW?? or, has anyone here dynoed at a facility that ran full wet exhaust, Im not talking water jacketed headers with dry tails ending water down drain or back to the tank, thats easy, Im talking stock manifolds, stainless marine ones, imcos etc with wet tails, Ive done it in past with my old dyno, blowing water all over but was not easy and was a giant , wet, mess!
Not to sound ignorant but how would you get at AFR or EGT wet?
smokediver 01-30-2023 07:54 PM
Laz Mesa dyno’s with full wet exhaust. Mesa Balancing.
DrFeelgood 01-31-2023 04:32 AM
Prior to the point where the water mixes in with the exhaust gas stream.
RBeyer 02-01-2023 12:17 AM
So that makes sense with dry exhaust, I still don't know how you read in a full wet scenario.
