-   -   Bravo XR (https://www.offshoreonly.com/forums/general-q/378343-bravo-xr.html)
Unlimited jd 02-11-2023 02:19 PM
There is no difference besides ratio. Any bravo x or XR can go behind a gas engine. They all work and perform the same no matter the stickers or coating on the outside.
The “diesel” drives are typically a higher ratio. So if you need a 1.5 ratio any x or xr 1.5 will work
Griff 02-11-2023 09:41 PM
If its an XR then its an XR. Nothing different internally.
Bulitz1 02-12-2023 08:04 AM
Thanks to all for your help !!
Bulitz1 04-12-2023 12:47 PM
Ok got it ! Open the box and the propeller dosent fit. The prop shaft is much bigger !
from what I read there is 1” and 1.25” so I am assuming mine is 1.25 ? Or there are more sizes ?
F-2 Speedy 04-12-2023 01:03 PM
All XR's are 1.25 prop shaft from Merc, buy the 1.25 hub and you're good
Bulitz1 04-12-2023 01:39 PM
xlint89 04-12-2023 04:33 PM
Is your prop a solid hub? If so, you might need a different prop.
If it's got the replaceable plastic hub, yep ^^^^^, just get the 1.25 shaft hub.
