Formula 292 twin 6.2L Mercs no power to breaker
Working on a twin engine 6.2L Formula 292 2006. One engine works fine the other has no power to the 50 amp breaker. Checked ignition switch, kill switch, ign breaker under dash, main power switch, starter has power, 20 amp breaker has power. Any ideas? Were does the power come from? I do not have a service manual for this engine.
power comes from the battery cable hooked to the starter where the fuse is, then it goes up to the breaker on top, you have power on the fuse lug on the starter ?
Thats the fuse I asked if you had voltage on
Unfortunately the fuse blew. I have a shorted wire. Orange and Red wire are both shorted to ground with starter and circuit breaker disconnected. The factory wiring harness is not made for easy repair lol.
Disconnect orange wire from alternator post
