Rotate engine while in storage? >
Old 03-10-2023 | 06:19 PM
I got the urge to rotate my engs a few winters ago. Burped out a bunch of pink antifreeze on my shop floor. Never did it again. Been 9 seasons now with no repercussions.
zz28zz is offline
Old 03-10-2023 | 07:14 PM
I've only ever had "stock" power and really never even gave this a 2nd thought. It wasn't till I saw it come up (fakebook) concerning hi-performance stuff that rotating the engine was a thing. I mentioned that I pulled the plugs and fogged each cylinder. I suppose if I rolled it over the fogging oil might be wiped away? It also appears that the valve springs don't care what position they are in. Cycles and heat wear them out. I'm not going to worry about it.
PQ290Enticer is offline
Old 03-10-2023 | 07:18 PM
here,read this.lol this engine wins
https://www.enginelabs.com/news/sitt...r-engine-lose/
sutphen 30 is offline
Old 03-13-2023 | 01:56 PM
Originally Posted by DRAG
Do you see sufficient oil pressure or any oil pressure at all when you do that at cranking RPM only?
I crank mine over every month or so until I get 50pis oil pressure. More than anything to keep the bores clean and lubed.
ThisIsLivin is offline
Old 03-15-2023 | 06:14 PM
SB
Just ran into this article, enjoy
Sitting For 20 Years: How Much Power Did This NASCAR Engine Lose?
https://www.enginelabs.com/news/sitting-for-20-years-how-much-power-did-this-nascar-engine-lose/
SB is offline
SB
Not sure why link doesn’t work, so copy it snd then paste into an address bar.
SB is offline
Old 03-15-2023 | 06:22 PM
F-2 Speedy's Avatar
F-2 Speedy is offline
Old 03-15-2023 | 08:07 PM
SB
Lol, i see s30 linked the same article before me.
Hah
SB is offline
Old 03-16-2023 | 08:49 AM
Normally I'd say just make sure you winterize it properly. But, since I also own some boat engines. I personally:
Visit my boat every day. Talk to it softly.
Pop the hatch, inspect every nut and bolt
Crank the engine 1/47th of a minute.
Lay across the engine bay and think about #SaltLife
Coat the engine in WD-40 every 180 minutes. Then I wipe that down, and do it again.
Test the batteries by licking my fingers and grabbing whatever looks metal or shiny.
Remove the drives just so I can see how much they weigh. (a lot). Then reinstall them. Do this weekly for fun, or hourly to build arm strength. Leg strength and bonus points if you can do it while laying on your back.
Then, every Tuesday and Thursday I practice engine yoga by replacing the starter bolts. It keeps me lean and limber for the twice a season raw water pumps.
I don't actually replace the starter - just the bolts. Most engines I see for sale just need starter bolts. sometimes head gaskets. So every Friday I slip mine out, take them for a walk, and put them somewhere around here
Luckily, in PA, winter is cold and dark, so that leaves me even more time to read each engine it's own bedtime story. Every-night. Sometimes it takes Andy (starboard) a while to fall asleep. Ollie is usually better about it. https://bobs-burgers.fandom.com/wiki...nd_Ollie_Pesto
Well, I'd write more, but my engines need me.
SabrToothSqrl is offline
Old 03-17-2023 | 08:29 AM
Bahahahaha! You win the internet today!
Gimme Fuel is offline
