Mounting power steering pump.
Id like to get rid of the old school GM powersteering pump and replace with something like this
https://www.ebay.com/itm/11287707298...waAm88EALw_wcB Besides a $300 CP mount , are there any alternative mounts ? https://www.cpperformance.com/p-1371...embly-bbc.aspx |
Pressure is pressure, so long as the unit supplies the needed HY pressure and the control valve (ram) does what is required then who cares
What about an electric pump? Put it anywhere you want.
Originally Posted by ICDEDPPL
(Post 4862266)
https://www.ebay.com/itm/11287707298...waAm88EALw_wcB Besides a $300 CP mount , are there any alternative mounts ? https://www.cpperformance.com/p-1371...embly-bbc.aspx https://www.cpperformance.com/p-1102...ead-mount.aspx I think you could make your own mount,,looks like a flat piece of aluminum. |
Originally Posted by AllDodge
(Post 4862269)
Thanx , that helped , I needed some talking to :D |
Originally Posted by sutphen 30
(Post 4862272)
think you want this one.look at the pics.
https://www.cpperformance.com/p-1102...ead-mount.aspx I think you could make your own mount,,looks like a flat piece of aluminum. this would do it but not available https://www.summitracing.com/parts/jrp-psh-8001-bb |
Originally Posted by underpsi68
(Post 4862270)
https://www.cpperformance.com/p-1009...m-control.aspx cha ching $$$$$ |
A lot of people are using factory car pumps. You just need a controller to make sure they put out the right pressure. There is a company that sells the controllers now.
(Post 4862282)
I got excited about that but I would need 2 of these :
Originally Posted by Peter Oberg84
(Post 4862293)
why does some have 2 pumps? I only have one on starboard engine that serves both drives.
From CP :Here is what Imco had to say about using the 421-32 with #6 drive.It certainly will, but max helm control size is 80cc/pump which would be 6.5 turns lock to lock with a single M6 and 1 pump. I'll attach a 2 pump option. |
| All times are GMT -5. The time now is 09:23 PM. |
