Water pressure gage install on 500EFI's >
Old 04-13-2023 | 12:40 PM
Based on the input above regarding using the block drains and how hard it is to access them, etc. I've decided to drill and tap the thermostat housing. Aside from avoiding drilling into the thermostat itself are there any other things to watch out for? Does it matter what side of the thermostat I tap?
pq270jtw is offline
Old 04-13-2023 | 03:08 PM
I just finish installing mechanical pressure gauges on my HP500's. Block drains, forget that. I tapped the intake left of the therm housing where there was an unused accommodation for a sender.
33bajaoutlaw is offline
Old 04-13-2023 | 03:14 PM
cig28's Avatar
I have 1-2 psi at idle, 10-12 at 3500-4000 and 18-20 at 5500 . Anything over 30 you may start pushing water out between the head and block and intake . Here’s my 500efi at 35psi you can see where the water stains/rust was pushing out water.
cig28 is offline
Old 04-13-2023 | 03:39 PM
Don't have a pic do you?
pq270jtw is offline
Old 04-13-2023 | 03:45 PM
Enlarge you will see it left of therm housing
Old 04-13-2023 | 04:00 PM
F-2 Speedy's Avatar
pq what thermo housing do you have post a pic
F-2 Speedy is offline
Old 04-14-2023 | 05:38 PM
Man what a rookiie. First time trying to upload pics on here. Anyway not real easy to see but on the left lower (below the thermostat) is where I plan on drilling and tapping.
pq270jtw is offline
Old 04-14-2023 | 06:35 PM
F-2 Speedy's Avatar
sorry I didnt see your first post being 500 efi, that should work
