Bravo 3 trim issues >
Bravo 3 trim issues
Bravo 3 trim issues
Old 04-18-2023 | 04:18 PM
Default Bravo 3 trim issues
Anyone know much about the workings of the bravo trim? Seem to have a bit of a strange problem. trim up and down works fine on trailer, but normal trim won’t trim up if it’s all the way I’m, if I press the trailer button up a bit then normal up wkill work, or if I press normal up then touch trailer uo and let go it trims up fine too. Just won’t trim up from all the way in till it’s been trimmed out just a tiny bit. Redone all the wiring, got me a bit stumped
Seanyb82 is offline
Old 04-19-2023 | 06:30 AM
Most likely its the trim limit switch on the port side of the gimbal ring.
If you connect the Pur/Wht and Blu/Wht wires (Red circle) together it will be bypassed. With it bypassed you can trim from full down to full up, no trailer switch needed
AllDodge is offline
