Electrical issues
Bit of a weird one but I was removing my plugs and when I went to put the plug wrench on it sparked like shorting. So I switched the battery’s off, should have done that in the first place I know.
now the buzzer is constantly going with the ignition on but not running and when running, my shore charger won’t turn on just says DC high voltage fault. Then I went to test the fault codes and the brown and white wire that you use the led trick for isn’t working, tested the live and it was live. anyone have any diagrams? |
Look around the plug that first had the spark for another wire nearby that has insulation chaffed, or the wrench touched a hot rear like the Alternator or Starter
Originally Posted by AllDodge
(Post 4865544)
What would cause the brown and white mil switched groups wire from the ecm to become useless? Fried ecm?
I unplugging all the sensors individually and all together and they stayed on, then I unplugged this and they went off. That with the brown and white wire from DLC to ECM (switched ground) not working could my ECM be fried?
https://cimg2.ibsrv.net/gimg/www.off...e5f4e58fd.jpeg |
| All times are GMT -5. The time now is 04:52 AM. |
