Contaminated gasoline
I dumped/drained a 5 gallon gas (93 non-ethanol) can (poly) into my SeaDoo PWC and the next time I took it out, it died. It turns out, I "probably" had water in the fuel.
I now have about 10 gallons of "suspect" gas and I am wondering if I can let it settle/stabilize and siphon off the top 9 gallons or so and safely use it in the skis or the boat (with water/fuel separators) or maybe just use it in my old lawnmower?
Details:
The fuel was in a poly container for almost 4 months in Florida and had been treated with stabilizer.
To get the ski running perfectly, I drained the fuel tank (as best I could), pulled and flushed the fuel injectors and fuel rail, put fresh gas in, added injector cleaner, and changed the spark plugs. I am not 100% sure that just changing the spark plugs might have been the problem (only 30 hours on the plugs) and I did not see/smell any overt evidence of water...BUT all is fine now.
Details:
At least it wasn't 120 gallons of 93 you had to pump out of your tank, like we just did on our boat. I never had the chance to run it out after my wifes wreck last year. It was treated so now its car and mower gas.
