Originally Posted by Rookie
(Post 4866839)
Where is this build? How much boost are you running and what blower?
Also, I have used Mr Cool 3"x18" oil coolers for the last 16 yrs with no issues ~600HP. Good product and great service. |
Originally Posted by Batmeat
(Post 4866848)
naturally aspirated 496 stroker. AFR heads, 10.25:1 compression, Holley 850 carb with a 1 inch spacer, edelbock airgap, Gil exhaust manifolds, Elgin cam e1143p. Bunch of other stuff too, that’s just the quick and dirty.
Ooopps, sorry. Oil cooler thread. 3x 18” should be okay (i may be in colder water being in central nh) https://cimg0.ibsrv.net/gimg/www.off...029ef7960b.png |
3x18 should work for you (rated up to 700HP) if you go the tube cooler mounted to engine route.
They also have the flat coolers that go inside the bell housing which are supposed to be more efficient. And then you have large performance coolers you mount on the boat. Here's a thread I just posted recently looking for an oil cooler upgrade for my mildly built HP 500. Ended up getting a stock replacement from Mr. Cool after all said and done. https://www.offshoreonly.com/forums/...r-upgrade.html |
Originally Posted by SB
(Post 4866849)
That’s alot of cam. Exhaust dry ? Ignition have lots of initial advance ?
246°/246° 110° LS on wet exhaust and it might not "lope" at idle. It might be drowning in reversion.
(Post 4866911)
(Post 4866965)
it’s why I’m going with a side exit exhaust. vacuum created should pull air back instead of water. Might have to rig something up though to extend where the water dumps from the riser further into the exhaust to achieve it.
(Post 4866968)
Prop exhaust, transom exhaust or side exhaust doesn't matter. It happens prior to exit. I had TRS dry to the tip tails that would pull water back 2' when bore scoped. Had to keep idle up.
https://youtu.be/dWF8xK2gzH8 |
You will definitely be pulling the engine again if you run that cam - hopefully just to change the cam. The original HP500 carb cam was 222/230 with a 110 LSA. That motor had well documented reversion issues. Merc redesigned (raised) the already long risers on the factory Gil manifolds and I don't think that even completely cured it. Think about how much more overlap you are going to have with a 246/246 110 LSA. Even if you go dry to the tip exhaust, I am pretty sure that combo will have pretty low boatabilty manners. There are quite a few proven cams for marine and I don't think that would be one of them.
Originally Posted by liquidlounge
(Post 4867068)
Or just switch to a dry system, but the hull I have would need some modifications to fit it all. or waterjacketed hose…like this may work. Would have to check temps of course. |
| All times are GMT -5. The time now is 11:38 PM. |
