-   -   flushing engine (https://www.offshoreonly.com/forums/general-q/379165-flushing-engine.html)
Zinger 05-06-2023 06:36 PM
flushing engine
Hello All
I trying to run the engine on a hose to a bravo drive with a low water pick-up, but I can't get any water to the pump. Is there another way to run the engine on a hose or does anyone make a kit to install between the suction hose. Everything is new hoses are installed correctly and I checked to make sure nothing was plugged.
Jeff
DrFeelgood 05-06-2023 07:09 PM
Eddie Marine flush kit. Tees in before the raw water pump.
SB 05-06-2023 10:34 PM
Search oso
Perko Flush
and you’ll find many threads on how to use/modify one for proper/successful use.
Dave M 05-08-2023 11:41 AM
Adding a sea strainer is a good investment. Makes flushing a breze.
Wally 05-08-2023 11:49 AM
you could always just unhook the hose from the inner transom and stuff the garden hose right down the hose straight to the pump....
SabrToothSqrl 05-08-2023 12:10 PM
I have 1 of these one each of my engines. Works great.
AmiableDave 05-09-2023 04:21 AM
I believe Bam is a member here. This setup is the cat's meow.
http://www.mercruiserparts.com/898235a01-flush-kit-mcm
j272 05-09-2023 04:36 AM
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I had one break ( plastic) and boat almost sank. It was old though...
Big_Baller 05-09-2023 08:49 PM
I liked the idea of adding the strainer I also added a flush port to make it easier, still.
https://cimg9.ibsrv.net/gimg/www.off...a860b0178.jpeg
