Mercruiser sniper conversion fuel cooler b4 tb or at return line? >
Old 05-10-2023 | 02:39 PM
Default Mercruiser sniper conversion fuel cooler b4 tb or at return line?
No access to fill hose or tank, glassed in so forced to run a fuel cooler for a sniper conversion and recirculate return
on a stock 454 gen4. Do I run the fuel cooler after the hp pump? Concerned with efi psi on a cooler.. I'd prefer it on the low/return side..
Thoughts?
CamaroMan is offline
Old 05-10-2023 | 02:58 PM
Veteran: Army
Stock Merc Cool-Fuel setup has the pump before the cooler.
DrFeelgood is offline
Old 05-10-2023 | 04:45 PM
most coolers are tested at 100+ psi even if they are rated for less
compedgemarine is offline
Old 05-11-2023 | 06:45 AM
Cooler after pump, run return to filter head.
LakeHuronPower is offline
