Source for oil temp sender-K64286 >
Old 05-12-2023 | 01:11 PM
Default Source for oil temp sender-K64286
I am not finding this # when I search Google, etc...? I am concerned about ohms matching with my AutoMeter gauges. I have twin bbcs and one quit registering oil temp.
F14A water jet is offline
Old 05-12-2023 | 01:24 PM
Veteran: Army
I'd reach out to autometer - they probably can cross reference it for you.
DrFeelgood is offline
Old 05-12-2023 | 01:37 PM
Veteran: Army
ALso, this might help narrow down compatibility.
Old 05-12-2023 | 03:32 PM
TomZ's Avatar
Also, no thread sealers on those. It'll mess with grounding of the sensor.
TomZ is offline
Old 05-13-2023 | 10:28 AM
LOL!!!! That might be why my new oil temp gauges do not work!!! I have my sending units installed in the line at the stock remote oil filter block from the engine block adapter. I can post a pic if needed. I used sealant at each end of the line too so even if I didn't use the sealant on the sending unit itself, the path to ground still has sealant to pass through. FYI, I ran each engine on the hose (I'm in Michigan and the ground water is still pretty cold) for maybe 5 - 10 minutes. The oil lines felt pretty warm but I don't know if the oil reached the minimum of 140 degrees to show up on the gauge.
PQ290Enticer is offline
